Question about Garmin nuvi 1450 GPS Receiver
My unit continues to lock up at difrent stages of turn on --then I restart it may get past the first point of lock- up or may advance a screne or so I have gone thoough this process for hours at a time------It moves very slowly from screne to screne--It is 6 months oid
  • 1,606 Answers
Something is definitely not right with it. First thing I would do is try a reset. You can access that from the menu and your user manual will tell you if your model has other ways of doing it (near the end of the manual under troubleshooting). Next I would look at the Garmin website for any updates or system patches for that unit. Apply any that you can get and see if that fixes it. Those two usually fix about 99% of things and the next step is contact Garmin support. Just go to the garmin site and look for the phone number for your area under support. They will probably get you to reset it first but after that they may have a unpublished fix or get you to send it in. Garmin support is real good so they do try to get you working un the least painful way they can. ;-]
Posted on Apr 04, 2011
..Computer screne is black,,d sub comes up and
Huh? D-Sub is a connector? If you plug an external monitor into it the laptop is probably designed to shut of the internal screen. If this is not what you mean please get someone who can write a functional English sentence to clarify your meaning.
Sep 21, 2014 | Computers & Internet
NO SATA drivers for MS-6728 ver:2 motherbaord, i am trying to relaod Window ME or even 2001 XP Prof but the computer keeps telling me that it cannot find the sata drive
First restart your computer and do it as describe below--
when your motherboard shows on your screne press continue "del" from your NUMPAD
it will be load your BIOS setup
go to Driver Updates option and update it.
After udate you just save it and restart.
Your problem is solved
Apr 29, 2011 | Microsoft Windows XP Professional
The washer will not advance to any stage. If
Have your Timer replace and be vey careful in the future when you changed your wash pattern.
People seem to turn that timer without a second thought as to do damage to the timer (the big dial) It can only take so much abuse
It is ging to break down
Jul 25, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
I have a cpu with windows xp and it wont go past the splashscreen
Please try the following:
1.
  • Click the start button
  • Right-click "My Computer" and select "Explore"
  • Right-click the disk (your primary hard disk, most probably should be the "C" drive) and select "Properties"
  • In the properties dialog click the tab "Tools"
  • Click "check now"
  • The "checking disk" dialog appears, check both options and click start
  • You will probably see a message that chkdsk wants exclusive access to the disk and therefore wants to begin first thing after you restart your computer. Accept by clicking ok.
  • Restart your computer
When your computer restarts you will see chkdsk advancing through several different stages of verification, examining your hard disk. If it detects no errors, Windows will continue to start to your normal desktop. If there are errors, chkdsk presents a report with what it has done and waits for your confirmation.
2. If the above doesn't solve your problem, repair the windows xp by doing as is given on the page at http://www.theeldergeek.com/repairing_windows_xp.htm (please see instructions under section "Windows Installation CD - Repair Current Installation:")
Dec 30, 2009 | Acer Aspire E500 PC Desktop
The dishwasher continues to drain and the timer does not move
Sounds like the timer needs to be replaced, especially if the tub is empty of water, and the timer will not advance no matter how long you leave it there.
Jan 24, 2009 | Avanti DW181SS Stainless Steel Built-in...
Bosch 3030 wash cycle does not advance beyond mid-point
The cycle timer is hanging at mid-point. You may have to replace it.
Oct 19, 2017 | Dishwashers
Mid cycle stop
the thermostats need replacing thers 3 of them you can get to them from the front its better to take the door skin off first so you can see better then take the lower panel off.the thermostats are on the right hand side underneath.
Feb 12, 2008 | Asko D1716 Built-in Dishwasher
Garmin nuvi 1450 GPS Receiver Logo
50 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
