Question about GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel
Freezer not sufficiently cold. - GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel
  • 132 Answers
I would sugest here that the freezer coil has frozen over blocking the air flow to the freezer.
The refrigerator section is still probably ok because the could air will drop down the air duct keeping this section clear.
Try manually defrosting the freezer and see if that makes a difference.
If it does you will need a technician to sort out the automatic defrost cycle for you
Posted on Apr 04, 2011
Freezer cools & makes ice but refrigerator side does not cool sufficiently.
First thing check and see if the fan motor in the freezer is running, it circulates cold air to the refrigerator. Then check for ice anback panel of freezer if there is ice you have a defrist system problem
Jun 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Would like to put older side by side refrigerator in our garage. I was told in the winter, when it gets cold the freezer side will not keep foods frozen. I had an older top freezer refrigerator in the...
It could be a problem depending on how cold your garage gets in the winter. Most refrigerators depend on the compressor turning on to cool the freezer section and that cold air is used to cool the refrigerator section. If your the temperature in your garage gets in the 30-40 degree range in the winter. The compressor may not turn on sufficiently since the refrigerator is typically around the 35-40 degree range. This will cause the freezer to warm up to the fridge temperature and your freezer items will defrost.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is not sufficiently cold. Changing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 14, 2010 | Sub-Zero Bottom Freezer Refrigerator
Freezer not geting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My freezer is working fine but the fridge has stopped getting cold
Hi, in the freezer there is a panel on the back wall, behind that panel is the evaporator coil and return air ducts going up each side, these ducts tend to freeze up, thus not allowing the cold air into the fridge part. If you can unplug the fridge overnight to let it defrost, that would be ideal, If you want to spend a couple of hours using a blowdryer that would be quicker, just be sure the ducts are sufficiently defrosted. they could be completely packed with ice from top to bottom
Jan 16, 2010 | LG Refrigerators
Refrigerator not cooling sufficiently/ Freezer not freezing
Yes, if defrost board is bad it will cause problems. Need to listen for fan inside the freezer compartment also. If freezer does not defrost cold air will not circulate properly causing warmer temperatures inside refrigerator. Is model number SXD524VW ?
Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Amana SXD524VW Side by Side Refrigerator
GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
