Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
I am looking for a chainsaw guide to cut felled tree trunks into even sized slabs for building furniture but am not sure what the guide is technically called. Can you help?
  • Husqvarna Master
  • 2,239 Answers
I have seen many chainsaw mills, some are fitted the the bar via some drilled holes, some are supplied as a double ended guide bar and take two chainsaws, they all perform the same task, some better that others, they are basically a frame with rollers that fit to the saw one way or another and are commonly known as chainsaw planking mills
Posted on Apr 04, 2011
How to install a new blade for my 10 inch electric chainsaw - model 358-34010
Loosen the chain adjuster and remove the bar bolts. Remove the side cover. Remove the existing chain. Thread the new chain over the sprocket making sure the drive cogs are engaging the sprocket correctly, then thread it over the end of the bar ensuring the drive cogs are inserted correctly in the bar groove. Install the bar/chain onto the bolts aligned with the chain adjustment pin and install the cover. Snug the bolts and tighten the chain with the guide bar tip elevated. Once you are satisfied with the chain tension, tighten the bar bolts and....... VOILA.... you are done. Head for that pesky neighbors tree that drops leaves in your yard.....
Of course, make sure the chain orientation is correct !!!! I have seen them installed backwards on the shelf in the big box stores....
Apr 19, 2015 | Craftsman Garden
Husqvarna 362xp Seems to lose power and struggle with felling back cut on big trees,20 inch bar on it,but seems fine when cross cutting big trees,any ideas please
It sounds like a "positional-related" problem, in which the first area I'd look at would be the fuel line in the tank and fuel filter. Hook and fish the line out and examine it (no kinks, cuts, hangs freely in tank) & clean/replace the fuel filter as that is the most likely culprit.
Oct 28, 2014 | Garden
SAP IN LEAKING FROM MY PINE TREE, IS THIS A SIGN OF BORES, MY APRICOT LOOKS THE SAME.
Sap is the pines natrural defense and protective measure when the tree has a break or cut in the bark or is being attacked by insects. So the sap could be seeping out from a broken branch or if it is a borer, there would be small holes(1/4 inch or less) in the bole(trunk) of the tree and there will also be sawdust coming out of the holes and around the base of the tree from the larvae eating the tree.
Oct 04, 2013 | Garden
What is the use of felling axes?
The felling axe purpose is to cut across the grain of wood as in the felling of the trees. There are different weights, shapes, handle types and cutting geometries to match the characteristics of the material being cut.
Feb 03, 2013 | Garden
My remington electric chainsaw 3.0 is not cutting and making a high pitch screech when i go to cut with it
Hello. Please make sure the saw brake is not set. This locks the blade so it cannot spin. If it is locked then if you try to rev the saw, the blade cannot turn and the clutch will scream. The other thing it could be is it sounds like the chain is out of the groove and the clutch is slipping BAD. UNPLUG the chainsaw. Check to make sure the chain turns freely around the cutter bar. If it does not move at all, you will need to closely examine the cutter bar to see if it has 'popped' out of the guide path. You must also make sure the chain is on the drive gear correctly.
These are 2 things to look at that can help you. Hope this helps..
Nov 04, 2012 | Remington Garden
Thomas the train misty island deluxe set instructions
Starting at the wood cut tower moving clockwise. Tower is 6. 6 to 7 to 8, L2, 9, L4,10,L5,11,fits into tree trunk, 14, (12 connects to the junction) 1, 2, (joins to 13 from the log over.) L5, 3, L4, 4, L4, 5, connects to 6, the tree tower.
The logging tower rails. Connects from 4 to 18, then the tall tower, the rail, the small tower, 17, L2, 16, L4, 15, the tall tree tower, 14, L4, 13 and that connects to No. 2.
L2 is the lowest support. L4 is the middle size. L5 is the tallest.
Nov 28, 2010 | Toys
Saw starts, but has no power.
Make sure air filter is clean.A blocked air filter will make the mixture too rich
May 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
When i try to do a horizontal cut my saw seems to bite in for a start, but then just runs free in the tree not taking a bite or drawing the saw in, this has also happened with 45% cuts, is this my own...
Sawing with a chainsaw is mostly 2 part, a sharp chain and good technique.
If your bar is straight, your chain is razor sharp and the oil reservoir full then it boils down to technique.
You cannot run a chainsaw through horizontally on a big tree, what will happen is half the time the tree's weight will begin to collapse upon the bar and pinch it in the tree and you will not be able to saw any further.
You will notice that when felling a tree the vertical cuts are always problem free because gravity pulls the off-cut away from the saw. With horizontal cuts fire your blade in at an angle, and in cut in the direction the tree (or whatever) is likly to fall. As you cut rock your blade to help it bite into the wood and resist jamming. If your chain jams do not keep on the gas for you will burn out the clutch.
For an awkard cut instead of feeding it right through cut towards the middle to create a notch, then cut from the other side, the weight of the tree will fall on the cut portion leaving your blade free to slice through.
Just think logically and make sure that the blade can feed through without getting pinched, this is well represented if you get a log and support both sides then cut vertically in the centre; it will get pinched imeediatly. Now cut from the underside and it will fly right through.
This is difficult to describe but plan your cuts and test it out.
Cheers,
Kevin
Feb 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvana electric chainsaw
Hi.
maybe its not sharper enough to cut those things that u r trying to cut.
check the saw tooth and use the chainsaw sharpener if u don't know how to make ur chainsaw sharpener take a look on this link.
click here.
i will fix u but you should rate me deal??
Aug 18, 2008 | Electrical Supplies
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
160 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
