Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error 42? - Canon PIXMA MP160 All-In-One InkJet Printer
    President:
  • 2,187 Answers
That may be a problem on the scanner side of the printer. See if you can re-attach the ribbon cables of the scanner.
Posted on Apr 04, 2011
How do I solve error 42?
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Lift Position Value Out of Range Precor Error 42
May 31, 2014 | Precor EFX 546i Elliptical Version 4
How do i solve error 42?
Model: All Models
Recommended Action:
May 29, 2014 | Precor EFX 546i Elliptical Version 4
I can't get a straight answer on how to reset my precor efx elliptical 5.21s, with an error code of 42
Model: All Models
Recommended Action:
Aug 09, 2013 | Precor EFX 5.21s Elliptical Cross-Trainer
Our precor elipitical is stuck at the top Error 42
Model: All Models
Recommended Action:
Mar 01, 2013 | Precor Efx-5.21 Elliptical Machine...
Error 42 on a precor treadmill
Model: All Models
Recommended Action:
Sep 13, 2012 | Precor 9.31 Treadmill
My Precor 9.31 has error 42 displayed and will not go away by holding down the QuickStart button;what is the next step?
Model: All Models
Recommended Action:
Precore C956 error code 42? solution? Unit is in remote location have not been able to get visual or repair, pre planning trip.
Model: All Models
Recommended Action:
Feb 22, 2011 | Precor C956i Treadmills with HR /...
I have a elliptical 546 i that show me error code 42, ramp goes up but no down, what should i do Thank for your help Byron
Model: All Models
Recommended Action:
Feb 16, 2011 | Precor EFX 546i Elliptical Version 4
Received err 42 on my Precor EFX 5.21s - what does it mean?
Model: All Models
Recommended Action:
Dec 28, 2010 | Precor EFX 546i Elliptical Version 4
Precor efx 546 error code 42
Model: All Models
Recommended Action:
Nov 30, 2010 | Precor EFX 546i Elliptical Version 4
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
50 people viewed this question
old marine
old marine
