Question about Sony Computers & Internet
Are there CPU fan settings in the bios of a Sony Vaio laptop model #PCG-3E2L? I know newer laptops do. I have replaced the broken fan, but new fan attempts to spin up on boot, but stops immediately. Speedfan is not showing any signs of locating a fan. Wondering if motherboard maybe toasty.
  • Sony Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 04, 2011
I want to clear CMOS
The CMOS is a block of static RAM that will lose its data if power is removed.
most newer laptops are using a small block of Flash RAM (perhaps a block of addresses within the Flash BIOS chip itself) or other type of EEPROM chip to store the password.
No amount of removing batteries and pressing power buttons will change it
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCG-3E2L
you might get some more information from the manual
hope this helps
Jul 24, 2012 | Sony VAIO Notebook
Why did the sony vaio pcg-3e2l is discontinued
on to bigger and better machines. sony just like most computer manufacturers create a model, sell it for a while, then move on to a new design.
Apr 04, 2012 | Sony Computers & Internet
How to remove BIOS password sony model PCG-3E2L
Remove the CMOS battery
If you attempt to pull the battery, make sure that you have all other sources of power disconnected (AC power and notebook battery). Keep the battery out for about five minutes before reassembling the laptop.
Aug 24, 2011 | Sony VAIO Notebook
I have a sony VaIO laptop model PCG-3E2L, and i have notice that it has been turning off by it self. i checked the ac adapter, and its ok.
The heat sink may be clogged with dust and ifthe BIOS temperature sensor controls the fan speed then it may be compensatingfor the reduced cooling by the dust build-up.
If you are not using your laptop on a flat surface, it may beobstructing the cooling vents on the bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust. A laptop fanassisted cooling pad may solve your problem
May 20, 2011 | Sony VAIO Notebook
How much is the price of pcg-3e2l sony vaio brandnew?
hi
go to following link you will find all prices
http://www.laptoppartsexpert.com/c-119992-sony-vaio-pcg-pcg-3xxx-series-pcg-3e2l.html
Jul 26, 2010 | Sony VAIO PCG-TR3AP1 Notebook
How much does it cost to replace fan on my sony vaio pcg 3e2l?
Probably about $20 for "parts",
and about $75 for "one-hour-labour" to open/change/reassemble/test the hardware.
May 14, 2010 | Sony VAIO VGN-CS220J/W Notebook
How much is a SONY vaio pcg-3e2l?
These are nice solid laptops, filled with memory and large HDD plus they have blueray. A good price for these can be 350 bucks used. Below is an item number for one that is for sale on ebay. Check it out as well as the specs....who knows, you want to bid on it. It is not mine, I just saw it on ebay.
#170419343276
Dec 14, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Unhappy fan noise vaio pcg 3c1m
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
Never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Nov 23, 2009 | Sony Computers & Internet
Vaio pcg-3e2l fan replacement/how to open for service
Ask sony first if they still cover the fan replacement for this specific model VGNCS220j/w
If they tell you they dont, then you can setup service for the unit in sony.com/repair
Sep 20, 2009 | Sony VAIO VGN-CS220J/W Notebook
Having a problem getting my Sony Vaio PCG-3E2L laptop to auto play my photo DVD slide show. Using Windows Vista Home Premium OS.Also, where can I find a PDF Sony User Manaul for my laptop?
A quick short cut is to open a browser if you use Internet Explorer and select tools menu, then select Internet options. When the box opens then select the advanced tab and scroll down until you see a check box under security and check allow active content from CD to run on my computer.
Also here is the link for your manual: http://esupport.sony.com/US/perl/index.pl
May 16, 2009 | Sony VAIO Notebook
Computers & Internet Logo
676 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
