Question about Mitsubishi WT-42311 42" Rear Projection Television
My picture is getting darker!
I can't seem to find a lamp for this model and if I did I don't know if I could replace it myself. Can someone help me please.
Mike in O'fallon
    Problem Solver:
This model uses three crts, no lamp.
Posted on Sep 17, 2008
Sharp LC-65d64u. Does this tv use a lamp that can be replaced
Refer its user manual and see there is any description about lamp repalcement. If yes, there is a lamp. If not there is no lamp. OK?
Gopakumar Gopalan Google
Feb 17, 2014 | Sharp Aquos Televison & Video
Picture is getting darker
Many of these DLP sets the picture gets darker right before the lamp fails.
Average life of the lamp is 2,000 hours----about 1 to 2 years of normal use.
If the lamp has not been replaced for a long time it is first suspect in this case.
Let me know if you have questions.
SD TECH
Jan 16, 2012 | Akai PT50DL24 50" DLP TV
Screen keeps going black
It is possible but the only way to know is to try that.
Lamps have about a 2000 hour life span which works out to about 2 years for the average user.
Usually in this model just before the lamp fails the picture either comes on somewhat darker than usual or gets dark just before the picture goes out.
The set will detect lamp is not bright enough etc and blank the screen.
The lamp light (I have seen this) sometimes will not come on even if the lamp has a total failure----no picture at all.
You might also check with a local shop or someone with the same model so you can swap lamps to see what the problem is.
Let me know what happens.
Dec 17, 2011 | Sony KDS-50A2000 50" HDTV
Darker screen after replacing a samsung dlp lamp
DID YOU USE THE FOLLOWING LAMP
BP96-00826A (PHILIPS WRITTEN ON THE LAMP)? ALSO PLEASE CHECK THAT THE LAMP IS COMPLETELY SEATED OR IT WILL RESULT IN BRIGHTNESS ISSUES. THERE WAS ONE THAT I REPLACED THE LAMP IN AND I NOTICED THAT THE DIAL OPENING ON THE LAMP HOUSING WAS A BIT SMALL AND WOULD NOT ALLOW THE COMPLETE SEATING OF THE LAMP AND I HAD A DARK PICTURE AS A RESULT. I USED MY CORDLESS DRILL WITH THE PHILIPS HEAD STILL ATTACHED AND REAMED THE HOLE LARGER AND IT SOLVED THE PROBLEM.
HOPE THIS HELPS.
Jul 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
50vx500
The lamps can do many odd things when they are on the way out includung the picture coming on and then dissapearing for a while then coming back. The lamps adverage life is 2000 hours, and at 3-5 years it is on borrowed time.
May 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture gradually got darker and less clairity
the lamps have to come out. the fluid has to be sucked out from the bottem.
Jan 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture seems to be alot darker than before. toshiba 62hm95
I just replaced a lamp in a Sony LCD projection that was just over a year old and it was bad. It was a VERY dim picture. You have a DLP but, in either case a dim or dark picture is almost always caused by the lamp.
Feb 23, 2007 | Toshiba 62HM95 62" HDTV
Mitsubishi WT-42311 42" Rear Projection Television Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
