Question about Sport & Outdoor - Others
My Beeman 1048 Air rifle is about 5 years old but has probably only been fired around 500 times max. Today I was target shooting and all of a sudden I could no longer crack the barrel/**** the gun. It's locked up tight. I opened up the gun and took out the pivot screw holding the barrel to the main assembly, which allowed me to **** it. But after reassembling and firing again, it won't re-crack. It's locked up tight. Any suggestions on what is wrong and how to go about fixing it?
SOURCE: beeman RS2 model 1074 pellet gun
i found a guy online and he was able to help me.not sure if i can tell how or who helped me so i better not. thanks anyway
michael
Posted on Mar 31, 2009
SOURCE: (DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Posted on Jun 28, 2009
  • 88 Answers
SOURCE: Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Posted on Aug 11, 2009
  • 29 Answers
SOURCE: My 870 Remington 12 ga. pump's barrel now moves
HELLO; Check and see if you have the barrel set into the receiver fully, and look at the receiver and see if it isn't split or the mag. hasn't become loose, I have two of these guns and Ive never had any problem like your discribing, but not to say it cant happen. PS make sure you retract the bolt before you insert the barrel in the receiver. GOOD LUCK....GREASY.
Posted on Oct 29, 2009
SOURCE: I have a Beeman RS1 air rifle,the gun shoots 12
look at the scope rings, see if they are mis-mounted or mis-matched.
Posted on Dec 24, 2009
Beeman air rifle no air pressure
Break Barrel Air Rifle Maintenance Part 1
Beeman Marksman
This might call for seals replacement. Don't lube these parts without confirmation of what to use at Beeman.
Aug 28, 2017 | Beeman Optics
How to fix my beeman qb78 co2 single shot airgun from leaking almost immediately after shooting it only a few times?
Hi.
Check this guy out archerairguns.info.
Before you strip down your rifle, try the oil treatment.
Oil seals dry out even from factory delivered guns. This guy runs you through the "fix".
Simple steps but you need to buy some Pellgun Treatment Oil.
It's only a small tube and this guy walks you through the steps.
They're really good guns and owners really love theirs.
Good luck.
Oct 05, 2016 | Beeman Optics
How do I tighten/ secure the barrel to the stock of my Beeman R9?
Has the stock dried out or the stock screws coming loose
Has the stock to action gap gotten larger if so you could try getting the synthetic stock
Sep 07, 2014 | Beeman R9 Air Rifle, No Sights - 0.177...
How to tell if i bent my r1 carbine barrel
If it was zeroed before the mishap try shooting a target to see if point of impact has changed if so decide to repair or replace damaged parts
Apr 01, 2014 | Beeman R1 Supermagnum Air Rifle, No Sights...
I have a 'used' Beeman Sportsman 1000 Series rifle (no scope). Have a pellet in the rifle (it's been in there for about a year, heh), I'm moving the lever-near-trigger back and forth but rifle won't shoot...
If your pumping the rifle and you hear air seeping out then the seal on your air chamber is bad or got pushed from where it is suppose to be, you can take it apart and see, its real simple...
Aug 03, 2013 | Beeman SS1000T Sportsmans Series .177...
How do you make adjustments, towards the shot or towards center of the target?
You move the cross hairs to the shot. Set up your gun on a bench and start by firing at a target out at about 15 yards. Once you are "on paper" set your cross hairs on the center and fire a 3 shot group Adjust the scope to the group. if the group is down 3 inch and left 4 inch. Adjust your scope accordingly. Then Fire another 3 shot group, until you are shooting center. Every time you adjust your scope tap the barrel of the scope with a screwdriver handle to keep the cross hairs from sticking. Once on at 15 yards move out to your max range and adjust to that.
Mar 19, 2011 | Brunton 2x20mm NRA Sports Optics Rifle...
I have a Beeman air rifile that I think is the greatest thing since sliced bread. I has taken down ground hogs at 50 yards. The rifle has a 4-14x56 Accushot scope mounted on it. When the rfile is working...
Unfortunately air rifles are hard on scopes due to the recoil...Suggest replacing the scope with something more of a brand model , like Bushnell or something like that..
Nov 07, 2010 | Beeman Optics
Good air pressure but pellet does not discharge. Firing pin is has hole in tip.
Check your piston is still connected to the piston ram they can come apart and piston stays at front of chamber whilst the ram moves
Feb 18, 2010 | Beeman 1024 Takedown Rifle, Scope, Rings &...
Beeman air rifle wont latch when cocking
you have a triger fault its not locking the piston back best and safest bet is a gun smith,, never play with a triger if your not good with guns,
Dec 25, 2009 | Beeman 1024 Takedown Rifle, Scope, Rings &...
I can shoot my centerpoint scope on my .22 and it
When adjusting a scope just move a few clicks at the time, after every few clicks tap the scope with a screw driver handle. Fire 2 rounds for group tap and fire the third round it should be in line with the 2. Keep that up till on target. Let the gun sit till cold and re-fire for grouping, 2 rounds, wait then the third. To keep shooting round after round can get the reciver warm enough to wedge the scope in its bases, causing your problem.
Oct 13, 2009 | Optics
Sport & Outdoor - Others Logo
135 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
