Saying that there is no signal for cable even though cable is plugged in
  • 373 Answers
I can give you a couple things to try, but you may need to provide more info like the model of the TV. New or old TV. New install? What was old TV; digital or tube? What kind of cable?
Touch the TV/VCR button or input button on the remote. Make sure you select the input option that matches your input. For example, my cable comes thru a multi cable box and happens to be "video 4".
Did you run the automatic search for channels?
Posted on Apr 04, 2011
Why does my Trutech say NO SIGNAL no matter what I do?
Video processor section should be checked. Contact any technician.
Jun 13, 2012 | Televison & Video
Onkyo receiver TX SR 605 saying no signal input from cable when everything appears to be plugged in correctly and powered on and it was working 10 minutes ago. All other connetions (Apple TV, dvd player)...
Hello, I am sorry about your issue. Please plug the cable box into a known good HDMI port on the receiver. Confirm that there are no issues with the cable or plugs. Thank you, CB
May 30, 2017 | Onkyo TX-SR605 Receiver
Entivoe DVD player worked fine. The next day, the tray opens, closes and the power turns on and off but the screen says only "Unusable signal", either with or without a video disc in the player. If there...
check the connection cable to the tv, unplug this an replug it to see if this helps.
if you used a cheaper HDMI cable for example the connectors are very wobbly and often make poor contact....
Aug 31, 2010 | Televison & Video
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
My lg tv (had since Nov) says no signal for the tv or dvd player. How do I fix this?
Try unplugging all inputs and the power cord from the TV for 5 minutes. This will allow the main board to reset.
Next, just plug in the power plug to the TV, power up the TV, and even though there is not a source connected to the TV, check at least three inputs and see what the TV will report on the screen for each input.
Next, turn off the TV, plug in all known working devices (Cable/Antenna, DVD, Blu-Ray, Cable/Satellite box, Game, ….) with a known working cables to the TV, make sure all the devices connected to the TV are powered up and on, and now power on the TV.
Now check to see if the TV is seeing valid signal for all the inputs connected to the TV.
If your TV cannot see any signal at any of its inputs (HDMI1, HMDI2, HDMI3, AVI1, AVI2, Component1, ……), then the main board has failed and need to be replaced.
Good Luck.
May 21, 2010 | LG 32LG40 32 in. LCD HDTV
The CC will not turn off on my LG plasma tv even though it says it is off. The cable box is service electric.
the cable box may transmitting the cc signal.use your cable remote to turn off the cc
Sep 05, 2009 | Sanyo DS31520 31" TV
Monitor says: no signal input check video cable Even though the computer is on.
Sounds a bit bland but either the monitor has failed or the video card
Only test is to plug your monitor into another system and see if it comes to life
If it does then your video card has expired.
If it is part of the motherboard then the easiest option is to buy a replacement which plugs into the AGP slot
They are dirt cheap unless you are into gaming when the sky's the limit
Jun 27, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
19" proview LCD monitor light and signal
How old is this thing? Mine is about 4 or 5 years old... junk it!
Mar 25, 2009 | Proview PL926WBi 19" LCD Monitor
Plasma 42 inch nec
the problem is most likely that there is no signal on the cable you are using.
check with a regular tv to make sure you have a signal.
Thanks
guy9
Jun 12, 2008 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
