Question about Necchi 3537 Mechanical Sewing Machine
I'm having trouble gathering fabric...no matter how I adjust the stitch length it seems to be too tight and I break the threads when I try to gather. Help!
  • Necchi Master
  • 1,128 Answers
So you are sewing two rows of straight stitch at 10mm and 20mm from fabric edge with a stitch length of 4? Are you using good quality thread? I like Molynecke, Guttermann or Sylko Supreme.
Try loosening the top and bottom tension too, and use a gathering foot if you have one.
A quick solution is to zig-zag over a length of pearl cotton or similar heavy weight string/thread, this works well for large volumes of gathers such as around a bed valance frill.
For large volume gathering like cushions and bed frills, I use a pleater/ruffler attachment, however, this has only 3 settings so isn't a variable gathering effect.
Posted on Apr 04, 2011
I am having trouble with my Singer sewing machine 367. I can't seem to get the tension right.
You really need to get a manual. Trying to figure out the problems is difficult if you are not an experienced sewer. There is a manual on eBay right now for your machine.
A little about tension. 95% of the time it is the top thread tension. It will be the thread on the bottom of the fabric affected. If the the thread on the top is loose it is the bobbin tension. Do not adjust both at the same time. Start with the top tension making small adjustments and then doing a test on scrap fabric.
Check to see if it is threaded correctly, without a manual it may not be obvious if it is or isn't. Check that the thread is between the tension discs correctly.
Jul 11, 2017 | Singer Sewing Machines
Can you gather
You can always gather on a sewing machine, no matter its age or model.
Usually, I like to set the upper tension looser so the upper thread shows on the bottom of the fabric. Set the straight stitch length to very long. Stitch two lines of stitching about 1/4" apart on the fabric.
how to gather fabric
How to Gather basic sewing tutorial
How to Gather Fabric Sewing Machine
Apr 29, 2016 | Sewing Machines
My stitch is set on 4 for length and tension is on the red lines touching. Yet it is gathering instead of straight stitch. Why?
Your tension is most likely too tight. Loosen the upper tension and retest.
Re-thread from the beginning. Make sure the presser foot is RAISED before threading the upper thread. This insures the tension disks are released and the thread will seat properly.
The ideal tension is when the upper thread and the bobbin thread meet in the middle of the fabric, but there should not be any puckering. Tension disks can eventually come out of adjustment so the red lines on your stitch tension may no longer be accurate. The tension will also need to change depending on the needle, thread, and fabric of the current project. Upper tension is not static. It needs to be changed to fit the project and a sewist should become comfortable with adjusting the tension for successful sewing.
Nov 19, 2015 | Sewing Machines
Top thread too tight. Bobbin thread too loose. Bobbin thread bunches up underneath material. The feeder teeth can not feed material through
first thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. .
Nov 03, 2015 | Sewing Machines
My stitch length is tiny and will not change
When selecting a stich, there's a button with a triangle with one edge pointing down. There you can select Needle Position and Stitch Length. --PDF manual, page 23
The thread tension has no influence on the stitch length. It just adjusts, where needle thread and bobbin thread 'meet' inside the fabric. A too high tension means, the bobbin thread is pulled trough the fabric and can be seen on the upper (needle) side. A too low tension means, the bobbin thread is not pulled through the fabric and you can see the needle thread on the bobbin side.
Jul 08, 2014 | Janome Memory Craft 9000 Computerized...
Bernina 1080 pleats the fabic of 1 layer on zig zag setting.I am trying to do the "cheats way " of gathering.Have adjusted the top tension ,changed thread/ needle.What can it be?
The fabric is tunneling? The pleat is forming the length of the line of stitches? http://crazylittleprojects.com/wp-content/uploads/2013/01/Z4.jpg Loosen the upper thread tension and increase the presser foot pressure and/or choose a flat soled foot, not an embroidery foot and/or add paper or other stabilizer on top of the fabric.
Or if the stitches are gathering up as you sew, go with it... that's what you're going to be doing anyhow, right? You can increase the amount of gathering by parking your thumb or forefinger hard against the needle plate behind the presser foot and allowing the fabric to pile up--- this is called "crimping" or "ease plus" and is commonly used for easing princess seams or sleeve heads. If it eases too much, clip the seam threads here and there and pat the fabric back out a little flatter, till it fits.
PS: If you like Gutermann poly threads, check the prices for Mara 100 at Wawak.com or similar pro sites. At Joann Fabric prices, you get an $8 spool of thread for $2.50 or less. Good stuff.
May 18, 2014 | Bernina Sewing Machines
When i do gathers on my machine i use the largest sticth,but the gathers r hard to pull. y/
Stitch length of 4, loosen your top tension by half a number and always pull up the bobbin threads.
If you need to gather yards of fabric then get a gathering foot. Janome make one - it looks like this
This foot is for creating soft gathers in lightweight fabrics. The underside of the foot is raised behind the needle and has a thick bar in front of the needle to gather the fabric. This works great to create the gathers as you sew. You can also gather and attach a ruffle onto a flat piece of fabric simultaneously, run the flat fabric through the top groove of the foot and the underneath fabric is gathered and stitched to the top piece, you need to keep the bottom piece feeding smoothly though so it takes practice to guide it evenly. Once mastered it is great to ruffle on valances and cushion frills.
Other option is use a ruffler foot, these will make a little ruffle every 12, 6 or 1 stitch so give a set result, and to obtain a more dramatic gather. They look like this.
The arm of the foot with a C'shape sits over the needle bar of the machine so it is moved up and down to activate the device. The little blade at the front moves backwards at regular intervals forcing a "tuck" of fabric into the feed to be stitched. Again you can ruffle and stitch to straight fabric at once but it is an art to master.
The weight of the fabric you are gathering is obviously the key variable, ginghams and poplins are lightweight so gather easily but if you need to gather something heavy like cordoroy it is going to be a battle and threads may break. If so, stitch two lines of gathers and don't try to do long runs, you'll just break a thread and have to start over.
Another good way is to zig zag over a length of perle cotton, taking care not to actually stitch the pearle at all. You can then gather up the fabric along it, this works well for heavier weights.
Oct 22, 2011 | Janome Memory Craft 9000 Computerized...
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
I have the singer 7442 and i cannot figure out how to get the baste stitch for gathering material on a flower girls dress. I've tried everything and there's nothing in the manual, can you help with this?...
Normally to gather fabric, you select the regular straight stitch, turn the stitch length up to maximum (4 or 5 usually), and stitch two rows of stitches, one at 10mm from edge and one at 20mm from edge.
Then gather by pulling the bobbin threads (underneath ones) from each end to gather the fabric. If doing lengths of more than 1 metre, then stop, leave long thread tails, and start a fresh length of gathering threads to avoid gathering long lengths of thread which might break on you.
If your machine has a basting stitch it might look like " .___.___.___" on the dial however, I've never been that happy with machine basting for things like attaching slippery fabric to underlining, I've always done it with needle and thread to keep the two layers matching and not stretching/slipping. For example, stitching a piece of chiffon to a underlayer of satin, even pinning carefully, these two fabrics will slip under the machine foot so I'd always do it by hand.
If you have masses of fabric to gather, sometimes what is quicker is doing a large wide zig zag over a length of perle cotton (heavier than thread) at the 15mm seam, don't let the needle pierce the cotton though. Then you can gather the fabric along the perle cotton.
Sewing machine instruction manual often assumes a knowledge of sewing techniques that you may not yet have. I have the Vogue Book of Sewing on my shelf and refer to it often. Or Singer do a good range of sewing books too, its worth investing in a good reference book.
I also love www.patternreview.com, this is such an awesome website for dressmakers/sewing enthusiasts and you will find loads of helpful tips here.
Hope this helps you a little.
Apr 16, 2011 | Singer 7422
Necchi 3537 Mechanical Sewing Machine Logo
198 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
