Was the battery cable removed recently? if so the radio may have theft deterant, were a code has to be put in just to get the radio to work again, call the dealer for the code, hope that helps
there is small pinhole on the front of the player, you need to push thin stiff wire (paper clip straightened up will do) and this will mechanically release lock on the players doors, retract the doors fully and remove the dvd's.
Most radios and cd players in cars require a code to get them operating again after they have been disconnected from the battery for an extended time. Hopefully a dealer could help you locate the code for that model.
CD HAS A GREASE FINGER PRINT SPOT ON IT CAUSE CD PLAYER TO LOCK START FLASHING.TURN OFF CD PLAYER FOR A LITTLE WHILE.THEN EJECT CD.SOME TIMES CD PLAYER WILL GET HOT CAUSE IT TO SKIP AND LOCK UP.IF IT DOES IT ALL THE TIME CD LENS NEED CLEANING OR PLAYER IS FAILING.IF ONE CD ACT UP ALL THE TIME.CD IS FAULTY.HAS FACTORY DEFECT OR DEEP SCRATCH IN IT.
You should have got a piece of paper from the dealer in your Manual that has the Vin number on it along with the code. I had to teach and locate my sister of hers,
If I unplug all the wires from the CD player won't the security system lock up my stereo system? Which means that I have to go to a dealer to get the code from them.
to enter your code when the cd player displays error leave cd player switched on and after 20 mins or so i will display 0000 then you will be able to enter your code this happens when some 1 has entered the wrong code
