Question about Schwinn Original Airdyne
Hace a second generation Airdyne that has not been used for 2-3 years. Started to use it today and could not move the pedals or handlebars at all. The locking mechanism was remvoved and still no movement. Is there a tension adjustment somewhere that I am missing?
2 Suggested Answers
  • 362 Answers
SOURCE: It seems as though my
if you have never replaced any components of your drivetrain-front gears- chain -rear gear cluster they will wear out simply inspect the gears visually they will be sloped back as not to be able to apply good pressure when pedaling your bike so this is where it gets tricky you need to replace it all together new as replacing anyone of the components will make it worse as they have worn to fit themselves so if you do replace which requires small amount of tools specific to the job you should have your chain checked any shop carries the tool to do this and most often will do it free of charge as they are gonna sell you a chain if its worn out past its acceptable stretch limit stick to this regimen and you will be a happy rider ps i replace my chain 3 times per summer lol hope this helps
Posted on Nov 17, 2010
What maintenance should be performed on a 12 year old airdyne that still works perfectly?
While I do not own an airdyne and have never seen one up close: To keep it working perfectly for a longer period of time, your bottom bracket bearings could probably use a little fresh grease as well as the 'wheel' or fan hub bearings. any moving parts that concact other parts might benifit from a touch or silicon spray or a bit of grease.
Oct 22, 2015 | Schwinn Original Airdyne
Tip
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
on May 23, 2016 | Schwinn Airdyne Exercise Bike
Squeaking belt on airdyne bike
I love my Schwinn Evo Comp AirDyne. After 2 years it suddenly developed a bad squeak and about .5" of increased play in the pedals (ie the pedal could rotate back and forth about .5" before turning the fan). Both these symptoms were caused by a broken spring in the chain tensioner. (Schwinn pn 13000371. See part 80 in blowup 5 of http://www.fitnessrepairparts.com/diagram/114 ~$9).
To replace this:
  1. disconnect the right hand (as you sit on it) connecting arm (ie the piece that connects the pedal to the big handle) from the lever arm (ie the big handle you pull back and forth) by removing the connecting bolt with an Allen head wrench and an adjustable wrench. Note the order of the three internal washers as you remove the connecting bolt. Rotate the connecting arm towards the back of the bike to get it out of the way.
  2. remove the four phillips head bolts that hold down large right hand plastic cover. With the connecting arm out of the way this cover can be pulled far enough out to gain access to the chain tensioner.
  3. remove the broken spring and replace it. I fashioned a similar spring with less tension which seems to work as a kluge. The original spring broke at the outermost loop, so I might have been able to reuse it by just bending down another loop.
  4. could lube the chain while you are in there, but you can also lube it anytime from the other side
  5. put it all back together
Jan 21, 2014 | Schwinn Airdyne Evolution Comp
Pedal / Chain shaft(?) problem
Sounds like you will need new bearings,check manufactures website for parts and instructions.shouldnt be a hard fix.
Nov 29, 2013 | Schwinn Airdyne Evo Comp Upright Bike
I Need Console for 1988 Airdyne
The age of the machine is not as big of a replacement parts hinder as is Schwinn going through so many buy outs since 1988.
One of the best exercise repair parts on online is FitnessRepairParts.com. They have consoles which are similar to your generation of machine for 170.00 - 240.00
Otherwise schwinn was most recently owned by Nautilus/Bowflex/LAMAR fitness and they may be able to help through their website.
Sorry, I don't have a great source of imformation to help with. I repair Schwinn exercise and it has become very hard to find parts recently as the new generation of AEROdynes are very different. Although, up until maybe 1-2 years ago, nothing had changed for 30 years.
Alternatively, search craigslist and ebay. You may have to buy an entire unit to get the part you desire. Often they have a drive mechanism worn out which devalues them to the seller, but has minimal to do with your search.
Good Luck.
Jan 06, 2013 | Schwinn Airdyne Ad4 Upright Bike
My Father has a schwinn Airdyne. the pedal was loose, I bought a new piece that fits through the pedal, replaced it but it is still loose. I think the medal in the crank wheel is worn...... Because the...
There is a metal shim needed in the bike/pedal that has to be tapped in to keep the pedal tight. If you dad has used the bike for several hundred miles and/or his feet might actually bend the pedals over time (weight), it is possible the metal piece that the pedal attaches to could become bent slightly, and I have seen a few bikes, that need to be taken to the bike repair store (call a large bicycle/itness store) that has a good repair shop and they often can repair these, but rarely less than $125 for an Airdyne repair/tuneup.
Feb 18, 2011 | Schwinn Original Airdyne
My schwinn airdyne has all of a sudden become much harder to pedal. There seems to be some kind of resistance. When I am pedaling and take my feet and hands off to "coast" the pedals make less...
An Airdyne is not a coasting bike, it is direct drive. The faster you pedal the harder it gets, that is the whole idea behind the machine. It is air resistance, not like the cheapies that you buy at discount stores. It is a professional machine that a Doctor can write a program for, sports teams use them also because it is a total workout. Where did you buy it? They can give instruction on it. If you are having problems with it, take it in for service it may need an overhaul. We have sold over 3000 of them since they came out in 1981, so I do know what I am talking about, they are worth fixing.
Dec 22, 2010 | Cycling
The handle bar got very loose while i was using it it suddenly went to the left this is a staionary bike the schwin areodyne can i fix this? i cannot afford repairs seems there is a big lug nut holdind...
http://www.fitnessrepairparts.com/diagram/113 This is an on-line link to the schematics for your Airdyne. The large nut between the handlebar (foot part) and the wheel hub are supposed to be pretty snug. Tighten the nut using a 6 or 8 adjustable wrench and tighten the nut clockwise. Be careful not to tighten too hard or the handlebar will not move at all. This is a very easy fix.
Jul 11, 2010 | Schwinn Original Airdyne
Northstar 5500 9HP Generator
Ok, try and take the bowl off and clean it out with some carb cleaner. Also open the carb top and shoot carb cleaner down it for several seconds repeatedly. If it has never been used it still was started and tested at the factory. It has gunk build up on the nedle and is probably stuck. This happens to alot of carbs even sitting for only a few years. Just take the carb apart as much as you feel comfortable with and spray carb cleaner all through it. Move the movable parts alittle and then try it. It has to work . P.S. Look in the gas tank and see if there is any rust in it. If so you need to pour some deisel fuel in it and sloush it around and dump it.
Dec 16, 2008 | Northstar Generator 9 Hp, 5500 Watt,...
Schwinn Original  Airdyne Logo
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
