Question about Panasonic Panafax UF-880 Plain Paper Laser Fax
Panafax UF-880 - no power
I cannot get the machine to respond when I turn it on. Is there a fuse somewhere, or do I need to replace the power supply? I found a manual online for the UF-885, which looks similar, but it contained no help for this issue, other than to check the power cord and reset the switch. I tried that and moved the machine to another power socket, but no joy. I also tried replacing the power cord with one known to work, also without success.
    Genius:
  • 2,120 Answers
Yes,
Sounds like the power supply.
Posted on Aug 31, 2008
SOURCE:
Panafax UF-880 - I would like to change Time and Date
Press
Function
71
set
key in the date and military time such as 1425= 2:25PM
set
stop
Jun 23, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Panafax UF-880 - volume of phone ringer
1- incoming volume press the down arrow till you want the desired level
2-outgoing volume. press monitor you will hear a dial tone. press down arrow till desired level and press monitor again your done
Dec 04, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
How to Set Date and Time
function-7-1-start change time and date
Nov 05, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
How to change the date and time on this machine Panafax Uf 880?
Now this solution isn't mine, I found it here and we can't even credit the poster since they were signed on as 'Guest' only:
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
1) select function #7
2) select #1
3) select "set"
4) enter the new date and time (MMDDYYY) (1500 - 3:00 PM) 5) select "set" and stop
Oct 31, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
PANAFAX UF880 - no power
This issue is under the wrong topic area. I have started another issue under the proper topic. Please ignore this thread.
Aug 04, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
How to set up Time and Date?
Press Function-7-1-start and you can adjust you time and date now. any other questions feel free to ask.
May 23, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Print Confirmation on UF-880
what you are looking for is a comm journal. to turn that on you need to press function-7-4-start-1-2-start-2" it will says always"-start-stop
your finish . good luck
Nov 13, 2007 | Panasonic Panafax UF-880 Plain Paper Laser...
Panafax UF880 shows message to check printer
This is a fuser problem (the hot rollers)it will require a service tech the machine has overheated and there is a service lockout to stop more damage from happening
Jul 25, 2007 | Panasonic Panafax UF-880 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax Logo
85 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
