SOURCE: driver for Polyview V17E 17" LCD Flat Pane
if you are using windows and it just won't let you go on the other resolutions try checking the monitor settings in your control panel
SOURCE: polyview v17e - microphone?
G'day Matt,
No microphone. It has a line in socket to drive the stereo speakers.
cheers,
dave.
SOURCE: need the polarity of the adapter for polyview v17e moniter
i'm guessing you don't have the original adaptor to test it... sometimes polarity is printed onto the case where the adaptor plugs in... get out your magnafying glass to see it tho.
SOURCE: no sound monitor speakers
At firs go to device manager and see you sound may already installed and ready for work, if so check have you connectd separate audio cable to your PC? You also can learn who is your sound card manufacturer by EVEREST download and intall it and it will show manufacturer and its support page.
SOURCE: when i start up my computer the screen is blank -
You may have to look at the setup menu to see if you can turn on 'AUTO SOURCE SELECT' and set to auto. You may have problem with the logic board that is why it cannot auto detect the DVI or VGA port automatically.
if your monitor has speakers, and it should built in; then you will see a separate lead with green plug on the end of it which is to be located in the rear of your pc with the green marked socket.
If theres no lead, then there must be a connector on the rear of the monitor
