Question about Air Tools & Compressors
What type, grade etc oil to be used in ingersoll rand compressor
    Problem Solver:
  • 5 Answers
HI;I AM ALAMOOT AND I AM A MECHANICAL ENG. THAT HAS BEEN WORKING WITH COMPS FOR 12 YEARS.I CAN SAY THAT EACH BRAND OF COMPRESSOR THAT HAS BEEN MANUFACTURED BY ONE COMPANY HAS ITS OWN OIL(MOSTLY THEY ARE BASED HYDRAULIC OILS,ANTI-COMPRESSED WITH SOME SPECIAL ADDITIVES THAT EACH BRAND PRODUCES FOR ITSELF. THIS IS DUE TO THE KNOWLEDGE OF THE MATERIAL USED IN THE SCREWS OR ..... INSIDE MATERIAL OF THE COMPRESSOR.
SO EASILY GO THREW THE MANUAL AND FIND THE RECOMENDED BRAND FOR THIS COMP.
YOURS FRIENDLY
IMMAN OSTOVAR
Posted on Apr 05, 2011
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
Oil type
reciprocating is iso 2100
rotary screw is iso 2046
sliding vane is iso 2150
Feb 17, 2013 | Ingersoll Rand Type 30 Electric Driven Two...
We have Ingersoll Rand Type 30 Reciprocating Air at about 20years old.. what type of oil is used in the crankcase?
Almost all compressors use sae 30, you can buy it labeled compressor oil. The key is compressors use a non detergent oil.
Mar 07, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
WHAT TYPE OF OIL CAN I USE IN MY TYPE 30 COMPRESSOR
I am sure Ingersoll Rand would like you to use there all season select synthetic oil, or you can use a good quality R+O 100 oil, also known as SAE30 non detergent. do not use cheap oil for gas engines,,, buy a good name brand from a regular oil distributor, and specify yo are using it for an air compressor. and most manufactures will recommend you change it every 3 months.
Jan 08, 2010 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand P185 WJD air compressor and I need to know the type and quantity of oil to use.
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Nov 03, 2009 | Ingersoll Rand Air Compressor Maintenance...
Type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Oct 30, 2008 | Ingersoll Rand Type 30 Reciprocating Air...
Air Tools & Compressors Logo
89 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
