Question about Rancilio (RAROCKYND) Grinder
My grinder was totally unresponsive when I turned it on although it was plugged into a working electrical outlet. It had been working properly and ceased functioning while it was in use.
Why isn't my grinder or burr mill working?
If your coffee grinder or burr mill stops working, please check the following:
  1. Make sure the unit is plugged into a working electric outlet.
  2. If it is plugged in and still will not turn, check to see if there are any obstructions around the blade. If there are, unplug the unit and remove the obstruction from the blade before reconnecting it to the power source.
If the above troubleshooting does not work, your product needs to be repaired or replaced. Contact an Authorized Service Center.
Sep 02, 2011 | Bunn NHB Coffee Maker
Why is my grinder not grinding coffe beans?
Hi dkmfix,
Plz follow the following link:
  1. Make sure the grinder is plugged into a working 120V electrical outlet.
  2. If the unit is not working, the lid may not have the proper sealing contact with the grinding hopper pin. Please contact the Authorized Service Center or check you warranty information. Please follow the procedures for sending the unit to a service center.
Thanx
Aug 26, 2011 | Gaggia Classic Espresso Machine
Plug in makita die grinder, turn on, runs for 2 to 3 seconds and pops breaker. It is a variable speed grinder
does it run freely?as in not seem to be lugging from bad bearings in the motor shaft,then check the speed control board for a shorted triac/scr transistor
Mar 25, 2011 | Makita 14" Die Grinder
My Mr. Coffee IDS59 coffee grinder suddenly stopped working. It is only a few months old. The blades turn freely when manually turned. Any helpful ideas?
Unfortunately this probably means that the AC Motor within the device has shorted out. These motors will still allow the blade/shaft to move even if a fault has occurred. It is unlikely, but possible that this particular model is built in such a way that a replaceable fuse is accessible to the operator. More then likely however the motor will have 'burnt' out and will no longer function no matter what you try.
Try to check the power cord for nicks and check that the outlet functions correctly. Lastly check that the power switch is properly operational. If all of this seems in working order then you are stuck with a non-functional device.
Mar 15, 2011 | Mr. Coffee IDS59 Electric Blades Grinder
Grinder doesnt grind beans although the motor works and the burr spins. I have cleaned it per the instructions and reassembled . Everything seems to fit together properly, but the beans don't seem to be...
I would suspect a log in the outlet shute where it goes into the grinds hopper. Clean it out and then turn the hopper to the coarsest setting to clean it out all together. Coarse grinds are a very good cleaner.
Oct 03, 2010 | Solis Maestro Electric Burr Grinder
My grinder is plugged in to a working outlet but will not turn on. Any suggestions?
No. 1: Check that there is current at the outlet, this can be done with a lamp or other 120VAC device. If no light (operation go to No.2, else No.3) No.2 Check that the fuse/circuit breaker corresponding to the outlet is fine. No.3 check any switch or fuse on the unit. No.4 Check that the pins on the plug make good contact in the outlet receptacle. Sometimes it is necessary to bend them a little bit. If none of this works, the other possibility is a bad power cord or broken motor.
Hope this helps!
Aug 17, 2010 | Craftsman Grinders
Grinder completely unresponsibe.
Hi
If you have tried opening the adjustment to a larger # and it still doesn't work. Well if the motor won't turn, I only hope the machine is less than a year old because the likely problem is the motor is bad. Sorry
Oct 25, 2009 | Rancilio (RAROCKYND) Grinder
Instant hot water dispenser does not heat water.
I had the exact same problem. I even replaced the first unit with a second unit...because I was sure I hooked everything up correctly. Then I called their support line and and felt very stupid. They asked one question "are you plugging in the Quick&Hot into the same electrical outlet as the garbage disposal"?. I said yes..and the garbage disposal works fine (thinking that this indicates a good electrical outlet). She then said "That outlet works off of a switch so no electricity is getting to the Quick&Hot until the disposal is turned on). Gosh darn it...that made total sense. I then tested this out by plugging an extension cord into a different outlet and it worked fine. Boy...do I feel stupid. Hope this helps.
Jan 17, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Whirlpool duet sport washer powering off during spin cycle
I had this problem with new duet sport washing machine. Service was out to fix under warranty (4 trips!) replacing water sensor and boards. Finally checked outlet and was told no neutral. ?? Charged us for that visit since not covered. Plugged into another outlet and it worked. Had electrician in, replaced original outlet (although saw no sign of bad connection) and washer worked again! Yippee until today when I had the same issues. Tried in another 2 outlets and still shut down after a few minutes (and in those few minutes it never really ran as it should) Went out to get an outlet sensor ($8 at hardware store). Plugged in and found no errors. Started washer again and it did run and completed cycle. Although estimate 1 minute of final spin cycle took almost 25 minutes (on QUICK wash no less!) Will have to monitor. See if we get lights on outlet sensor next time washer doesn'twork, see what other things in house are running, etc. (although washer on dedicated line). ONLY change since this happenned: We replaced our 30 y.o. electrical box. You'd think this would be better???
Nov 30, 2008 | Washing Machines
Unit will not turn on
I plugged in the coffeemaker at an outlet in a different room in the house. Apparently, none of the plugs in the kitchen worked (although) other appliances did work in the kitchen outlets (very strange, perhaps the coffeemaker needs more juice than other appliances) Now I have to have an electrician come out and fix the kitchen outlets...
Aug 23, 2008 | Cuisinart Thermal DGB-600 Grinder
Rancilio (RAROCKYND) Grinder Logo
81 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
