Question about HP LaserJet 2840 All-In-One Printer
I have replaced my imaging drum and now 59.99 eror turn of and back on will not go away any help fixing this problem would be great. Regards, Dale.
  • HP Master
  • 1,915 Answers
From the HP service manual
59.99-T2 Clutch error: Check the cable
connections to the DC controller. If the error
persists, remove the imaging drum and
check the clutch. If the error persists,
replace the T2 clutch. If the error still
persists, replace the DC controller
(seeRemoving the DC controller
Any chance you got a bad drum unit? It could be binding which would cause this error.
Posted on Apr 04, 2011
I'm replacing my starter relay, 3012-5a A1G7 Cubigel SA and overload and forgot which lead to connect it to.
Dale:
I'm currently researching a related question and found this image. It may be what you need.
Dennis
Feb 16, 2015 | Furniture
Hi, we have the hp color laserjet 2840 series and we are getting a supply error (10.1004). The picture shows that there is a problem with our imaging drum. We bought a brand new imagind drum and it is...
Reseat the toner cartridge. Turn the printer off, and then back on again. You may want to try a new cartridge, but if that does not eliminate the error, call your HP support line. If the imaging-drum light is still blinking but the Attention light is not on, you must replace the imaging drum before the printer can continue printing. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition. The printer has determined that it cannot read or write to the e-label on the imaging drum.Reseat the imaging drum, and then power cycle the printer. If this does not work, replace the imaging drum. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on. If the problem persists, replace the imaging drum E-label reader. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition.
If Hope that this helps,, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks,Joe
Feb 04, 2011 | Office Equipment & Supplies
My Dell 5110CN printer is printing a double image
I am having the same problem, and I am using the original toner cartridges that were supplied with the printer, so yes, they are genuine Dell toner cartridges.
Dec 27, 2009 | Dell 5110cn Laser Printer
Rear Drum Brake Install
Removal & Installation
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Remove the drum retaining nuts, if equipped, and remove the brake drum.
If the drum will not come off, pry the rubber plug from the backing plate. Insert a narrow rod through the hole in the backing plate and disengage the adjusting lever from the adjusting screw. While holding the adjustment lever away from the screw, back off the adjusting screw with a brake adjusting tool. Be careful not damage the notches in the adjusting screw or the self-adjusting mechanism will not function properly.
  1. Inspect the brake drum for scoring and wear. Replace or machine as necessary. If machining, observe the maximum diameter specification.
To install:
  1. If a new drum is being installed, remove the protective coating from the drum using brake cleaner. Sand the drum lightly and wipe with a cloth soaked in denatured alcohol.
  2. Adjust the brake shoes according to the procedure in this Section.
  3. Install the brake drum and the wheel and tire assembly.
  4. Lower the vehicle.
http://www.chiltonlibrary.com/content/images/8665/images/86659045.pdf
http://www.chiltonlibrary.com/content/images/8665/images/86659046.pdf
The 2 links are diagrams for shoe placement and the automatic brake adjuster.
Be sure to have the drums turned before installing the brake shoes.
Hope this answers your question. Best of luck on your repair.
Greg
May 28, 2009 | 1983 Mercury Marquis
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
Apr 27, 2009 | HP Color Laser 2550N Printer
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
F2-57 Sharp AR C160 color copier
F2 usually means its a component failure that should be looked at by a technician. You could trying turning it off wait 30 seconds and turn it back on again to see if it goes away.
Jul 23, 2008 | Sharp AR-C160 Color Copier
Large grey streak down center of page
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Nov 16, 2007 | Brother IntelliFax-2820 Laser Fax
HP LaserJet 2840 All-In-One Printer Logo
212 people viewed this question
Seeker5211
Seeker5211
