Question about Kenmore 63942 Dryer
Kenmore dryer 68932790: Push start button starts but when you release the button, it stops. Plus, no heat.
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Posted on Mar 26, 2007
SOURCE: My Dryer Starts, then stops as soon as I release the button.
Its possible the dryer heat selector is at fault. If the timer inside does not move to the end of the heat cycle you may have further problems. Depending on how old the dryer and how long it has taken to dry garments, you may want to check that the motor has not gone bad causing an electrical overload. Faulty timers will cause extended drying times eventually putting a strain on the motor's bearings and electrical windings. You may want to get a replacement or get a repair estimate to repalce the belt, motor, drum rollers and heating coil components.
Posted on May 19, 2007
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
rickzilla
  • 706 Answers
SOURCE: Kenmore Elite Dryer, model#11062942100.
In all probability, you have an open thermal fuse in your dryer or ( depending on the model) you may have a motor switch that is not making the circuit remain on. These switches use centrifigal force ( when the motor rotates up to speed ) to keep it on so that you can release the start switch. Hope that helps..
Posted on Nov 26, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Series 90 dryer will
You have a broken belt.
Posted on Mar 10, 2009
Have a kenmore elite quiet pak ll gas dryer start buton doesn't start. when release the button dryer stops
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
Jul 02, 2010 | Kenmore Dryers
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
PUSH TO START BUTTON DOES NOT WORK
its not the start button check the door switch if broken or actuator is broken you get the results as you dry
Aug 21, 2009 | Kenmore Dryers
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Start button doesn't work properly
Hi, You have a motor going bad. The start winding is out on it.
The motor will need replaced.
Vic
Jun 25, 2009 | Kenmore 659 Electric Dryer
Kenmore Elite Dryer stopped working
most of the time if you push the start and it drags the motor is getting to weak to turn the drum(bad motor)if it's not heating also,it might be the heating element or the heater box fuse.if it was me i would sell it on craigslist for parts,and buy another one on craigslist(great deals)
Apr 20, 2009 | Kenmore Dryers
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
May 12, 2007 | Kenmore 63932 Electric Dryer
Kenmore 63942 Dryer Logo
76 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
