Question about Mitsubishi WD-52528 52" Television
The picture quality on our WD 52528 is horrible - dark, blurry, and hard to see picture at all if not looking at the tv straight on.
  • David Petry Apr 04, 2011
    What are you using for picture in, ie; satellite receiver, cable box, etc. and are they hd tuners? Do you have your input to tv run through HDMI or component?
  • dana_herring Apr 04, 2011
    We are attempting to use satellite; however, we are having issues getting our satellite to configure to the tv as well. Yes, the satellite receiver is an hd tuner. I am not sure about the tv input.
  • 961 Answers
Your satellit receiver should have the capability to hook to your TV either by using HDMI cable out from sat unit to HDMI in on TV. This sgould give you sound and audio, or it should have component output which is a series of three cables red, blue and green.The component cablesdon't provide audio so you have to use digital optical or composite cables for sound. Whos satellite box are you using?You should be able to press your menu and get into "system set up" and, there should be an option for HDTV. Go for the highest resoulution(1080 And a ratio of 16 x 9. You tv manual should tell you about screen set up. Let me know
Dave
Posted on Apr 04, 2011
LCT TV picture blurry with black smudges until it warms up
No easy way short of monitoring with a scope and or voltmeter, based on age of set I would first "look" at all the filter caps in the main power supply--bad ones when they get hot can regain some function:
Dec 09, 2012 | Televison & Video
I have a mitsubishi wd52 52528 connected to uverse.....i cannot get hd for some reason, the sbt says it is dispaying 1080i but the tv says 480i ......help????
Make sure you have it connected to the correct input---one other thing if you have not tried it unplug set and HD box from power for a short time and plug them back
The set has a soft and hard reset, the soft with the original remote is Menu, 1,2,3 enter.
Dec 08, 2012 | Mitsubishi WD-52528 52" Television
The image projected by the tv is extremely dark and hard to see with daylight
Your lamp is going out. it will dim for a time before it dies. check online for a replacement lamp
Mar 12, 2011 | Mitsubishi WD-52528 52" Television
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The screen seems dark and blurry
take off the front panel carefully, usually 2 screws around the controls. Next, stick your head in and look at the red green and blue tubes. see if they are dirty? if, not look further into the tube using aflaslight and see if there is a white pasty looking substance inside. IF so, you need to clean as you have bacteria growing in the cooling fluid. A big job and you need the gaskets, can order from Mitsubishi tech support..good luck be careful.
Mar 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blotchy picture
I get this too with my Samsung. Are you watching HD content or standard (cable, satellite) tv? If it's the latter, that's why. The lack of quality really shows on analog signals. The shows that I Tivo look horrible a lot of times. Another thing is the connection to the television. If you are using standard RCA connectors, try switching to either component or HDMI.
Hope this helps.
Feb 01, 2008 | Samsung DLP HL-P5663W 56" TV
JVC resolution problems
replace ..display defective....
Nov 24, 2007 | JVC GM-V42UG 42 in. Plasma EDTV
Mitsubishi WD-52528 52" Television Logo
370 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
