Question about Le Chateau All Ceramic Condezza LC Collection 5811L_BLMOP Watch for Women
How do I make the band smaller on my ceramic watch
  • 2,334 Answers
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes
Posted on Apr 04, 2011
escapement
  • 2334 Answers
SOURCE: how do I adjust band on a guess g95290g guess steel mens watch ?
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
Job done!
Don't forget to rate, please.
Posted on Feb 16, 2009
vsndesigns
  • 5 Answers
SOURCE: Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
http://www.rgmarchitect.com
Posted on Feb 09, 2008
SOURCE: Band adjustment
I was able to take use a push pin (thumb tack) to get out the (split) pin. I put the thumb tack in the hole of the pin I wanted to remove, place the thumb tack upside down on our counter top and gently but firmly push the pin out. It only has to push out an 1/8 of an inch and then you can pull it the rest of the way. Thanks to the diagram that "guest" posted above - I copied and pasted: http://www.pmwf.com/Watches/WatchSchool/WS%2014%20How%20to%20Resize%20Common%20Bracelets/WS%2014%20How%20to%20Resize%20Bracelets.htm#Split%20pin%20bracelets in the browser and it showed me how the pins work in the wrist band. Didn't need all of the fancy tools. (:
Posted on Mar 18, 2008
escapement
  • 2334 Answers
SOURCE: I have a Sweda watch with a link type band and I
Click on my profile (escapement), then click on Tips and Tricks. There you will find explanation how to remove or add bracelet links. Rate me, plz.
Posted on Feb 12, 2010
SOURCE: I want to size my wife's Peugeot ceramic watch
I just got finish resizing the White Ceramic Peugeot watch I bought my wife. It's very simple to do
Posted on May 20, 2011
Replace links on Swiss legend ceramic watch
here is a video that will show you how to remove links on your ceramic watch band
Jan 18, 2013 | Swiss Legend Karamica Chronograph Ceramic...
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
I have a michael kors white ceramic watch and the band is too long? how do i remove links?
Ceramic links break VERY VERY Easily!!! Take your watch to a reputable watch repair shop and have them adjust your watch band! :-)
Jan 15, 2010 | Watches
Cant get the white band clean
I love watches. My collection: Breitling Colt, Bulova Accutron, and a few others.
Yours is no slouch either. I believe it's around $2500. and the band is special, very special. It is made from ceramic and can not be replaced with any other band except for the one it came with. That being the case, if you are going to pay that much for your watch you should expect some quality service from the maker in regards to things like this. So before you do anything else give them a call and ask them if they have any recommendations about cleaning it.
If you get a response some thing like "No problem just send us a blank check and the watch and we will fix it right up, Honest" tell them to get ben........never mind. Just hang up. Their # 1-888-455-9200
If you are going to try and clean it you need to understand just how hard ceramic is. I have ceramic tool cutters almost as hard as diamond cutters so it will take some patients.
The first thing I would try is to let the band soak in bleach. You might be surprised at how well that works. Let it soak awhile. The longer the better
The best thing is to find a polish made specifically for ceramic.
I would try a auto paint supply store. They should have good quality polish for ceramic clear coats. It may also be a good idea to get a piece of white ceramic cutting plate/board and test a spot. I would also use a small Dremel polishing wheel. Dremel also makes a soft polishing stone that you mith want to try depending on how bad the stains are.
Remember a ceramic cutter board is a cheap way to test before you try anything on the band.
I really hope something here helps.
Let me know if you need any other help and please let me know of any success or failure and I'll try and give additional assistance.
Dec 29, 2009 | Nixon 51 30 Tide Watch
Replacement acrylic watch band
I posted the other same request...all I've been able to find is ceramic replacement bands, and nothing clear. These run about $200.00 and for that price we should just replace the watch with a "Toy" which it is copy of...
Jan 18, 2009 | Anne Klein 10 7977MPTT
Fossil watch band adjustment
throw the ******* thing away
Dec 26, 2007 | Fossil AM3695 Wrist Watch
Le Chateau All Ceramic Condezza LC Collection 5811L_BLMOP Watch for Women Logo
420 people viewed this question
Top Le Chateau Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Le Chateau Watch Expert? Answer questions, earn points and help others
