Question about Air Tools & Compressors
I HAVE A CAMPBELL HAUSFIELD THAT came with my compressor and i tried it for the first time toniteand it worked for about 3 nails and then it would shoot air but not the nails. what is the black ring around the top of the gun for? the number on the gun is DJ0508.
  • 2712 Answers
SOURCE: how to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Posted on Aug 27, 2008
  • 18 Answers
SOURCE: oiling my nail gun
You simply put a couple of drops of pneumatic oil in the air chuck on the handle every time you're going to use it, and then hook up the hose.
Posted on Nov 15, 2008
  • 1383 Answers
SOURCE: bostich gun problem
If the piston/driver is broken, the gun will fire however nailing will not take place because the piston will jam in the cylinder. Sometimes the cylinder will also crack when the driver goes. If the piston is not broken but stays down, then check the cylinder check valve, worn lower bumper, bent driver or cracked cylinder. 18 guage nailer has a very thin driver which will easily bend or break. Parts however are not expensive.
Posted on Nov 25, 2008
  • 1383 Answers
SOURCE: replaced leaking trigger valve wit new valve kit.
I have seen many small bostitch guns all with different problems that did not shoot nails. Both of your guns have simillar triggers. You might try the trigger valve from the gun that works to see if that is the problem. Most no fire situations come from faulty trigger valve. The trigger valve used in your guns has a part that stays in the body of the gun; be sure to replace both parts. If still no fire check the following:
Remove the head and check if the piston/driver travels all the way down the cylinder with the tip of be blade showing at the nose. Some piston/drivers have a grove that must be aligned.
Check that the headvalve travels into the head and returns. Push the valve in with your thumb then cover the small vent hole at the base of the head where the gasket sits with your finger and release your thumb. The headvalve should be held in with vacuum then pop up when you remove your finger from the vent hole. If the headvalve does not stay pushed in with the vent covered, the orings are leaking and can cause the gun not to fire. Try lubing the headvalve with light grease such as silicone lube. Do not use bearing grease. Silicone lube is available in small amounts at plumbing supply/lumber outlets such as Lowes. It looks like wax feels like shortening.
Reassemble the gun and check your work. I test the gun with-out nails and without the trigger installed. Just place the nose of the gun on a piece of rubber, (I use a piece of heavy garden hose rolled up tightly into a coil) and press the trigger valve pin with your finger. The reason that I leave the trigger off is that sometimes the problem is caused by the safety mech not pushing the trigger pin correctly. enjoy
Posted on Nov 29, 2008
  • 1383 Answers
SOURCE: porter cable roofing gun
The problem that you describe could be caused by three things. First remove the cylinder and look for a black rubber band around the cylinder about med section. There is an indention with holes where it is supposed to be. The band should fit snuggly so that it does not slip off during use. Secondly, check that the piston oring/plastic ring holds the piston in the cylinder without just dropping under its own weight. Third, the upper bumper could have a crack or missing piece. Remove it and check. (vinyl part in headvalve) Parts are available at dewalt repair center or www.toolpartsdirect.com. enjoy
Posted on Dec 07, 2008
What type of oil is needed in my Durabuilt air compressor-6 gallon tank? I need to replace some oil. Thanx. Send response to "gfrommell@wi.rr.com." Thanx.
Howdy. It's actually called Compressor Oil and is available at nearly all hardware stores and tool rental agencies. There are several brands and they are all comparable. I use Senco, but Campbell Hausfield is also good. Farmerbear at FixYa.com
Oct 23, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Campbell Hausfield Air compressor Mod. HL421500, One year old. My compressor is running but will only put out 10 Psi.
The valves are bad. Replace them with a valve plate kit from ToolPartsDirect.com.
Sep 14, 2010 | Garden
Compressor problems when filling tank
There should be a device called an "unloader " connected to the machines own switch. This releases the pressure from the compressor so it can start up without the resistance of the pressure in the tank.There should be a hissing noise when the machine stops, the sound of the air on the compressor side of a non return valve being released.
Jun 03, 2010 | Campbell Hausfeld 13 HP 30Gallon Air...
I bought a HS5180 air compressor from WW Grainger. I lost the manual, and directions to install. Can you please email them to me? Thanks Jeff
Jeff, you can go to the Campbell Hausfield website, and download all of that. You can save it as a PDF file, and just print it yourself.
Apr 08, 2010 | Campbell Hausfeld 5 - HP 80 - Gallon Air...
My campbell hausfield wl660001aj will not come on and I changed the fuse also. 5 gallon vertical
Water is condensed from the compressed air it makes and this can settlel in the switch diaphragm, in cold weather is can freeze and prevent the switch from working.....
Feb 02, 2010 | Campbell Hausfeld Air Tools & Compressors
Wanting to adjust my cut off pressure down...its at 135 now but have in line tank, campbell switch 60 gallon
If I read your problem you would like to decrease your pressure setting on a campbell hausfield compressor, this usually can be done by turning the 3/8" nut (typical) counter clockwise which decreases the spring tension on the pressure plate allowing less pressure to break the points. Hope This Helps Don
Dec 02, 2009 | Campbell Hausfeld Air Tools & Compressors
Air compressor not working, campbell, hausfield turns on but doesn't make loud noise it used to seems like it is not kicking in. It just sounds like a loud vacuum cleaner. Campbell Hausfeld WL6501 13...
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Apr 11, 2009 | Campbell Hausfeld Air Tools & Compressors
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Wiering
look at the motor nameplate it should have voltage and fla which is full load amps this should be calculated by an electrician for wire size hope this helps
Aug 05, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Air Tools & Compressors Logo
41 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
