I am trying to make a copy of a dvd that I made and am having difficulty. I originally got a 204 error and now it is saying ""No Writers Enabled!" How do I fix this... I have a huge deadline to get this copied.
  • 27,725 Answers
This error is a registry problem
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software or only if you don
Posted on Apr 04, 2011
My dvd player on recognizes original dvds but wont read any burnt dvds...WHY???
most of the laptop dvd drives have slower reading speed(about 2x) and writing speed(about 24x) compare to desktop pc's(about 8x and 52x respectively).
ur problem might have occured if the writing speed by which the cd was burnt might not be compatible with ur dvd player.
try playing dvds which were burnt using laptop dvd writers.
also try changing the modes in which the dvds are burnt.
Jun 19, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
Keep getting "Target Overflow" error message, even
you may have a bad ROM. If you have a multiple target unit, switch the source from the ROM to one of writers and try copying that way, if it copies then it confirms that the ROM is defective.
If you have a Single target unit, check your master disc under disc info, depending on which controller you have it should be under utility or disc info. Once in disc info it should tell you the size of your master disc, for DVD-R it should be under 4488MB, for DVD+R it should be under 4482MB. Then double check the master in the PC just to confirm.
Jun 12, 2011 | EZ Dupe EZDupe Two Target DVD Duplicator...
When I put in a dvd it will say "blocking." I
check the type of dvd you put in: is it original or copy?
Jun 07, 2011 | Philips Televison & Video
Fails to finish copying and burning cd/dvd
If you have changed the writer, the operating system, and the burning software, I would suggest changing the make of the DVDs first. If that doesnt change anything, would be looking at a faulty motherboard to be honest.
Jun 08, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
BURN FAIL ERROR CODE
I suppose that you have a DVD writer or a HD DVD drive installed by default. I am having the same problems on an Aspire 5920 G with a HDDVD Toshiba and the problem is because of mister Bill Gated and windows vista... the drivers for DVD RW and HD DVDs are all messed up in vista and they enter in conflict with those from the burn program. ERROR 204 corresponds with "POWER CALLIBRATION ERROR" witch means that the beam could not be centered on the row it was writing or that the beam could not write on the disc. You can try a google search for youre dryve type firmware and upgrade it. To find youre drive tipe go to device manager DVD/CDrom drives and copy the name of the device (eg: if it is TOSHIBA DVDW/HD TS-L802A ATA Device search for "TOSHIBA TS-L802A firmware" on the web and upgrade the firmware to the newest on the market). Alternatively you could install windows XP and vurn from XP and you will not experience any problems
Jun 16, 2009 | Acer Aspire 4930-6862 Laptop
Error code 204 when backing up to DVD on Acer Aspire 5515
i was having same problem.  went home and tried again with a different brand of dvd and it worked on the first try.  definetly a different brand and not sure but i think the one at work was just a dvd-r  the one i am using at home that worked is an RW.  maybe the process writes something again so you need this kind of disk.  hope it helps.
Apr 07, 2009 | Acer Aspire 6930-6455 Notebook PC
Trying to copy a DVD
Sometimes different DVD software and DVD writers are picky with the type of DVDs that you put in. Try a different brand and see if that makes a difference.
Nov 26, 2008 | Roxio Easy CD & DVD Burning
My DVD player no longer plays original dvd's - only copied dvd's
some times when you create DVD movies by high speed DVD writers, your data cannot be read by dvd player with high performance. it s due to speed mismatching. always write DVDs with Normal speed in order to use with DVD players. while in case oof PC-DVD -Rom it does not happens. it can read any high speed wriiten DVDs. DVD-Rom in PC are more precise than DVD players. Some times Weak DVD player Lens system can also mis read.
Dec 22, 2007 | Philips LX3000D System
Unable to copy dvd's using pioneer dvd-rw dvr-112d
maybe the DVD have a copy protection system
A COPY GARD
you need to decrypt the original DVD's first then burn them off using shrink or nero recode or even dvd decrypter itself
Nov 08, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
DVR-111D dvd/cd writers
hmmm, this is unusual, it appears to be an incompatibility with the DVD software, as everything else seems to work may I suggest that you upgrade your DVD software for a later version.
May 23, 2007 | Pioneer 16X DVD Drive Burner (Model...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
