My fan has quit working. Will this cause the computer to start up then shut off after about 30 seconds?
  • joecoolvette
    joecoolvette Apr 04, 2011
    Absolutely. The fan is used to cool the hardware components inside the computer. One of the main hardware components is the Processor. A Processor operates at a certain operating temperature. (Thermal Limit) If this temperature is exceeded the Processor turns off. This is a built-in fail safe feature designed to keep the Processor from burning up. It is suggested the fan be replaced. Regards, joecoolvette
  • 961 Answers
Yes, it is a protection thing. If it can't sense the fan it will send an error and turn system off before overheat.You can go to "device manager and click on box next to "system devices" and see if your fan is in there and if there is a warning. If it will stay on long enough.
Posted on Apr 04, 2011
    Sergeant:
  • 163 Answers
It very well could cause that type of behavior as it is most likely reaching too high a temp and shutting down to protect it's self. A fan replacement is recommended.
Water temp gauge works for about 30 seconds and then drops to zero
Most likely have a bad DIM. You may start to see the SRS light start coming on and the speedometer may stop working.
Nov 29, 2015 | 2002 Volvo S60
Acer Aspire One notebook.when turn on,starts to boot goes windows did not start screen,can choose option and windows starts to load then just shuts off.if you do not choose option shuts off after about 20...
This is generally a hardware issue - if the computer is under warranty get it fixed through Acer. If not you may need professional help. You don't mention how old the laptop is but if it is older than a year or two and you live in a dusty environment it could be overheating. If the fan is not running or always running on super-high then it is probably overheating.
Another thing to try is using a boot CD (any boot CD will work) and see if the computer still shuts down after that 30 seconds. If yes, definitely hardware. If not, possible that it's a windows issue.
Hope that helps!
Dave
Oct 21, 2013 | Acer Aspire One PC Notebook
My acer aspire one netbook keeps shutting off thirty seconds or so after it starting. Sometimes a screen appears saying that there was a problem shutting down and it gives me options of clicking Safe Mode...
Your ventilation fan may be clogged and causing the computer to overheat.
Try a can of compressed air "AIR DUSTER" and a vacuum cleaner to clean the fan.
If this is not the problem, you may need to repair the windows installation
Aug 01, 2010 | Computers & Internet
Satellite P35-S611 (PSP30U20H001) PC Notebook: what causes the p 35/30 shut down as soon as you t...
The processor is over heating. I have a p-35 s6053 and it used to do the same thing until I fixed it.
Do the fans come on or anything when you first try to turn it on ??????
I'd bet the fans come on strong and then after about 5-60 seconds it just shuts off. let me know if i'm right and I can tell you how to fix it,
May 17, 2010 | Toshiba Satellite P35-S611 Notebook
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
My Fujitsu Siemens Scaleo P tower fails to boot up, sometimes shuts down after a few seconds, no output to monitor. Can you help My computer works fine untill one morning it shut down with no warning....
pop the CPU, take a closer look athe chip and the socket, make sure there is nothing can create a short of creating any kind of heat. if you don't find anything there, I suggest a new CPU in order.
Apr 17, 2009 | Fujitsu Siemens Computers & Internet
Fan won't shut off w/remote.
Does the remote have a dedicated button for off/on lights, and then off/on fan?
I assume it used to work,,???
First, regardless, replace the batteries in the remote, even if they are new.
This will do two things, reset the remote and double check the remote is powerful enough to send a strong signal.
Do you have the original set up manual for the fan?
If this is not a new install, and it simply quit, get out the manual and perform the original setup.
Sometimes there are "modes" setup on the fan by how long the wall power switch is on or off, say on for 30 seconds puts it in test mode, or on/off in less than 30 seconds puts it in operational mode.
Not knowing what you have, I cannot say that you need either a new fan or new remote, I need more information about the entire situation.
write me at service @emrrepair.com
Will
Nov 29, 2008 | Hunter 52" Ceiling Fan With Light And...
The laptop doesnt start up. cooling fan is brocken. thermal oil is old and almost dry and little
Sometimes depending on the version of BIOS there is a thermal shut down feature,If the CPU gets to hot it will shut the entire system down.What you can do is replace the CPU fan and apply more grease in between the heat sink and the CPU chip.If this does not solve your problem then you may have damaged the CPU.the best way to fix this is to replace the motherboard and CPU.Try replacing the fan first because if your computer has the thermal shut down feature then chances are that it protected the motherboard and CPU from any damage.Try the simple things first! GOOD LUCK.
Nov 13, 2007 | Toshiba Satellite A45-S250 Notebook
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
