Question about Frigidaire ATF6000ES Front Load Washer
I have a model gltf 1040aso front load waster. After loud bang after which there was extreme vibration and noise I took the covers off the washer. If looking form the rear of the washer there was a hole in the plastic enclosure for the tub on the left side approx 2in X 2in. You can see the pulley on the inside through the hole. Washer will run but very loud and vibrating. Is this a fixable problem that is also cost effective? Regards, Paul Colburn
SOURCE: frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Posted on Nov 02, 2008
  • 3 Answers
SOURCE: FRIGIDAIRE MODEL #FTF2140ES2 FRONT LOAD
Did you check that the door lock switch is working?
See this thread:
http://www.applianceblog.com/mainforums/showthread.php?t=3124
If it's not the door-lock switch, you need a new speed control board.
Posted on Jan 19, 2009
onthejob5130
  • 640 Answers
SOURCE: Washer is extremely loud
defective back bearing and spin basket..onthejob
Posted on Feb 03, 2009
Healeyman
  • 1198 Answers
SOURCE: Vibrating when spining
An underloaded machine can get out of balance because there's not enough clothes in it to shift around evenly. Don't do small loads. Check to see if a drum spring has broken, you may have to pop the top to see. A putty knife at the top front corners will release the spring catches for the top.
Posted on Apr 27, 2009
SOURCE: Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
Posted on May 21, 2009
I have a frigidaire #gltf 1040aso Washer fills ,but the wash cycle will not start! replaced door lock & timer! still will not start washing!
Hi sdwach852 - From what you are describing it sounds like the washer could possibly be experiencing a wiring failure or have a faulty control board. Consult a professional for an accurate diagnosis and to assist with the repairs.
Feb 08, 2013 | Frigidaire ATF6000ES Front Load Washer
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
A loud banging noise at start of spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 04, 2011 | Tricity Bendix AW1054 Front Load Washer
Very loud banging on fast spin
heatman101
Sep 17, 2010 | Whirlpool AWM8113 Front Load Washer
Whirlpool WFS1276AW bangs loudly when rinsing and spinning
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Sep 06, 2010 | Whirlpool LHW0050PQ Front Load Washer
I hear a loud ratteling noise coming from where
The rattle is likely a loose shield or a bad catalytic converter. As for the loud banging, Have you checked the front U-joints behind the brake rotors. As for the Reverse noise? Auto or stick shift?
Apr 16, 2010 | 1996 Jeep Grand Cherokee
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
53 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
