Question about Car Audio & Video
I installed a aftermarket head unit in my 2002 Malibu; right now I did the fuse tap thing that came with the metra 70 - 2003 wiring harness but the head unit doesn't cut off when the car is off. Then I did some more research and seen that if I wire the accessory wire into the accessory wire of my ignition switch it would fix that problem. I would like to do that but I don't have the slightest idea where to begin with that I mean maybe if I could get the color code to the wiring harness attached to the ignition switch or even a legible wiring diagram for the harness I would be very appreciative.
  • 625 Answers
The radio accessory wire is brown at the ignition switch. If the ignition switch is to the left of the stereo, remove the stereo to access the ignition wires.
Posted on Apr 04, 2011
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Need to know how to install my deck in my 1999 chevy suburban
The best way to install an aftermarket stereo is to go to a stereo installation store and get the in dash "metra" kit and the wiring harness adapter that allows you to connect the aftermarket stereo wiring to the factory wiring on the truck...the "metra" kit adapts the aftermarket radio to fit into the space for your particualar vehicle..the tech at the stereo store will know what all this means if they know what they are doing...To clarify, "metra" is a brand name for these kits andthey also go by the name scoshe...
Jan 11, 2011 | Alpine CDE-7872 CD Player
Im installing an aftermarket sterio in my 95 jeep coerokee,and none of my speakers will work... how do i bypass my factory amp so that my door speakers will work? pleeez help!!!!!!
you can do one of 2 things , run wires from each speaker to the head units speaker wires or locate an amp bypass harness from www.metra.com, sometimes theres a tiny amp on each speaker as well , i doubt it for the year of youre truck but it may have at least a factory amp . u need that bypass harness
Nov 26, 2009 | Car Audio & Video
Stereo diagram for 1990 geo prizm
Hello stoogieprezi,
You should have gotten a plug-in harness with your new Alpine. To avoid cutting or tapping the wires on your vehicle, you need to purchase an aftermarket wiring harness. It appears that the Metra 70-1782 is the correct one for the 1990 Prizm.
Then you simply match up the wires on your Alpine harness with the Metra harness. The wiring color code for the harness is shown on the bottom left of the "description" tab and matches up with the Alpine color code on page 18 of your owners manual.
Hope this helps.
Jun 10, 2009 | Alpine CDM-9821 CD Player
Connect jvc kd-lh1150 in elantra 2001... different connector
Hello claude_bouth,You need a vehicle specific aftermarket connector generally called a "wiring harness". Your JVC came with a plug that fits the back of the receiver with "pigtail" wires which you splice to the harness wires. http://www.SonicElectronix.com sells the Metra 70-7301 which appears to be the correct harness for your Elantra.You can tap into the wiring of the car harness and splice the wires by function into the appropriate car wires, but using the aftermarket vehicle specific wiring harness is a lot easier and you don't need to disturb the vehicle wiring in any way, just plug into it. It also makes it possible to re-install the factory radio if you ever need to do so. If you choose to tap and splice, you can find your Elantra's wiring color code at http://www.modifiedlife.com.Hope this helps.
Jun 05, 2009 | JVC Arsenal KD-LH1150 CD Player
Hi, I am installing a new head unit into my dads 98' Buick LeSabre and the factory harness has been cut and I'm not sure of the color code and not sure how to run the extras thru the new head unit and how...
Metra makes wire harnesses for your problem. If your wire harness is, 70-5555 the part that goes into the OEM radio will be 71-5555
Try www.metraonline.com and put in the car info. The harness will come with wire codes for splicing the new plug.
Dec 17, 2008 | Car Audio & Video
Stereo Upgrade in 1997 Sentra
hi there. I am not sure about the speakers. But there is a wiring harness available for a aftermarket head unit. I have a '97 sentra the base model XE version. I have just put in an alpine head unit and you defenately hear the difference even on factory speakers. But you will need 2 kits to install an aftermarket head unit in the car. 1. A dash kit. I got mine from canadian tire for about 20 bucks, it comes with instructions on how to put it together and its straight forward, just make sure u get the one for your year and make of car.
2. The wiring harness. there available at mostly every car audio place for about 10 bucks. again make sure u get the one for your year make and model of car. installing this is difficult so unless your good at electronics get it professionally installed. you have to splice the wires into the back of the aftermarket unit, then the plugs plug right into your existing factory car harness.
hope this solves your problem, the dash kit is easy to put together and install into the car, but the wiring harness is a bit difficult, i had my harness installed for about 40 bucks and u save money if u put the dash kit togehter yourself because thats 1 less thing they have to do. good luck.
Nov 29, 2008 | 1997 Nissan Sentra
Installation of new cd player in 2002 VR-X Lancer
There are aftermarket wireharnesses available. I suggest the $15-25 purchase. The wires usually match color for color to the aftermarket stereo saving a major head ache if attempting to figure out the factory harness. These adaptors are available at many audo part stores and local installation shops. To check the harness you need, Metra, on of the main aftermarket wire harness manufacturers has an application chart on line, see metraonline.com or a search for American International or Scosche.
Nov 14, 2008 | 2002 Mitsubishi Lancer
No volume
The Bose system in the Z is wired to control the entire car's speakers. Each speaker has its own amplifier, and the OEM head unit puts out a line-level signal to each amp. Your Clarion unit puts out speaker-level signal (in effect, an amplified signal), into the Bose amps, and it's probably overdriving them and putting them into shutdown.
Your best bet is to replace the Bose speakers with aftermarket speakers meant for a speaker-level drive (which is what I did in my Z, and never once regretted it). If you do so, you'll need to run new wires to the speakers, or if you use the OEM wiring, you'll need to unplug the amps and run the wires from the amp harnesses directly to the new speakers. I think there is an adapter harness you can use that will tap into the line-out jacks on your Clarion, so that a line-level signal can be sent to the Bose speakers - I'd do a google search for "Metra harness 300zx" or something along those lines (Metra makes the lineout harness adapters - I use one in my Audi).
Sep 16, 2008 | Clarion DXZ755MC CD Player
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
