Question about Canon PowerShot A3000 IS Digital Camera
LENS ERROR WILL SHUT DOWN RESTART CAMERA IS THERE ANY WAY TO GET RID OF THIS
  • Canon Master
  • 17,970 Answers
This link can find details about everything you can try to fix it without sending it to a repair shop: Fixing-lens-error-on-digital-camera
Hope helps (remember to rate and comment this answer).
Posted on Apr 04, 2011
wipdhuls
  • 133 Answers
SOURCE: len error restart camera canon IXUS 80 IS
Its also known as E18 error and you would be surprised to see how this issue is resolved .. check the fallowing link:
http://www.e18error.com/posts/index.php
Posted on Apr 02, 2009
  • 641 Answers
SOURCE: lens error
It seems as a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Sep 04, 2007
t00nz
  • 4738 Answers
SOURCE: Canon Ixus 130 gives message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Jul 31, 2010
duane_wong
  • 6826 Answers
SOURCE: camera reads "lens error, will shut down
The gear mechanism is binding inside the camera. Needs service through a Canon Authorized Service Center.
http://www.usa.canon.com/cusa/online_repair_tracking/consumer/digital_cameras/powershot_sd_series/powershot_sd1400_is?pageKeyCode=requestRepair
Posted on Aug 17, 2010
lock123
  • 6831 Answers
SOURCE: lens error . will shut down automatically.restart
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 10, 2010
Lens error
"Lens error, restart camera". Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here's an article and here's a video that shows some things that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Nov 14, 2011 | Canon PowerShot SD1300 IS IXUS 105...
The lens is stuck out and it says lens error restart camera any thoughts on how I can fix this?
This is a very common problem, deb-ri builds up over a period of time and jams the lens housing. Get a can of compressed air attach the straw and aim it in the crevice between the camera body and camera housing, "give it one or two blasts" turn on to see if will retract, if no! lightly tap the lens body with your side finger "gently" if yes! aim the lens down, and open shut a few time in hopes getting rid of any lingering dirt.
Jan 17, 2011 | Canon PowerShot SD600 Digital Camera
Lens malfunction, "Lens error, restart
Dec 27, 2010 | Canon PowerShot S5 IS Digital Camera
Lense error, restart your camera
If i told you to smack it around a bit would ytou believe me?
But that is the fix Canon use to get rid of these errors 98% of the time.
Charge or change the battery, insert it tuen camer on when it goes off smack it hard into your palm a few times and turn it back on.
Just incase there is some dirt/dust stopping the lens from extending blow a can of compressed air around it and give it another few slaps . Sometimes after about 20-30 ngoes of this the camera will jump back into service Believe me it does work nearly all the time Canon charged me $90 to do this trick
Jul 29, 2009 | Canon PowerShot SD850 IS Digital Camera
Len error restart camera canon IXUS 80 IS
Apr 02, 2009 | Canon IXUS 80 IS Digital Camera
Says lens error restart camera
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 06, 2009 | Canon PowerShot A590 IS Digital Camera
Camera turns on BUT then get "lens error restart camera" msg
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2008 | Canon PowerShot S3 IS Digital Camera
Open Questions:
See all Canon PowerShot A3000 IS Digital Camera Questions
Canon PowerShot A3000 IS Digital Camera Logo
781 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
