Question about Husqvarna Garden
I have a husqvarna 141 chainsaw and it dies as soon as it starts. It is full of fuel and had fuel filter replaced.
  • Husqvarna Master
  • 2,239 Answers
If you have changed the filter the next port of call is to service the carb, remove the top cove and air filter, remove the two 10mm nuts holding the filter back plate and remove the plate, now remove the two 7mm bolts holding the carb, remove the two cross head screws holding the ignition switch, and carb plate, lift out the throttle push rod, and diss connect the fuel hose, the carb should now come away, uner the cover with the single cross head screw ( pump side ) will be the pump diaphram, under here will be the main inlet screen, make sure this is clear, under the cover with the four screws is the metering diaphram, and under here is the inlet needle, replace both diaphrams if the appear aged or are distorted or hardened.
Posted on Apr 04, 2011
How to replace fuel pick up,line in Husqvarna 1414 chainsaw?
You need to remove carb and then you can access the hole for the fuel tank. you need to go to a Husqvarna dealer and get the correct line. if too big wont go in if too small will leak replace fuel filter when you do it.
Oct 14, 2014 | Husqvarna Garden
Were is the fuel filter on a husqvarna 142 at
Its in the gas tank, also check for dry rotted gas line.
Oct 02, 2014 | Husqvarna 141 142 136 137 Cylinder Piston...
Husqvarna 141 starts with choke and then cuts out
If the chainsaw has been used recently i would say It sounds like the screen filter inside the carburetor is dirty item # 507432582 or the metering diaphragm is dried out item # 530035165. Also check that the fuel lines are in good shape. If that doesn't solve your problem you should do a pressure and vacuum test to check the seals and gaskets.
Feb 01, 2014 | Husqvarna Garden
No gas in carb husqvarna 141 chainsaw
Fuel gets to the carb via the fuel filter in the tank, the fuel hose up to the carb, and the impulse from the engine making the pump diaphram in the carb pulse and pump fuel, so start by replacing the fuel filter in the fuel tank, then check the fuel hose for signs of leaks, the impulse from the engine is fed through a pipe in the carb support block, you will need to remove the carb and block to inspect this, there is also a filter within the carb itself, this is sited under the pump housing of the carb ( alloy cover held with a single screw )
Oct 05, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna model 359. Starting as per normal with full choke till it fires then half choke to start. Revs up one time then dies and I have to start the process over again. Wont run at all. Any...
Fuel starvation, replace the fuel filter in the tank, check the fuel hose up to the carb, pay special attention to where it leaves the tank as they do perish, failing this then there is dirt in the carb.
May 30, 2011 | Husqvarna Garden
Starts ok soon as u try to rev it bogs out die new carb no change checked muffler it ok fuel filter fuel line allok
Does it have plenty of compression, they are very prone to gummimg the piston ring in if you have been useing a large fuel oil mix.
Feb 11, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Chain saw mod 141 dies out when given full thottle
Your air fuel ratio is off and or your fuel filter is shot. Best to let a good shop handle this unless you have done lots of them
Mar 07, 2010 | Husqvarna Garden
''How do I change the fuel filter on a Husqvarna 141 Chainsaw''
Hi michael
Just follow the fuel hose from the carburator and see where it is entering in the fuel tank.Fill out the gas from the fuel tank.At the end of the fuel hose is the fuel filter.Take them out (hose filter and fuel filter),then change it.Disassembly the carb and carefully cllean the inner parts.
:-* best wishes savumihai71
Dec 04, 2008 | Garden
Garden Logo
103 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
