Question about Refrigerators
I have a whirlpool fridge freezer, the light that comes on when fridge door is opened, blew at the week end a spark came out of the light panel and left a small burn mark around light panel, the motor and freezer is still working fine, but I have turned it off for safety reasons. Can this be easily fixed
  • 132 Answers
The flash of light may have been caused by a loose light fitting, you should get a technician to have a look at it
Posted on Apr 04, 2011
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
May 17, 2012 | Hotpoint Refrigerators
Fridge light comes on & sound but not cold
The freezer fan motor may be bad. The main back panel in the freezer can be removed to check it out. Spin the motor wiht your finger to see if it tries to run. If it does then it is shot.
Go here for:
Whirlpool Refrigerator Parts
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
Apr 11, 2009 | LG LFC21760 Bottom Freezer French Door...
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
No power to control unit in fridge
Turns out we had a bad control board. One of the coponets was blown and it had to be replaced. $400.00 and its good as new.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
Dec 26, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
