My Electrolux xl8 front loader washing machine has stopped mid cycle and the door's red light is on and locked. I cannot restart the machine by pressing the 'start' button. i cannot open the door when power on or off the machine will not start in any other program cant start or get clothes out
SOURCE: indesit W93 washing machine
We have W124, it allmost completed renewed inside. Thanks 3 years warranty and new service engineer, motor was changed and then all problems disappeared.
Posted on May 01, 2007
  • 1462 Answers
SOURCE: stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
Posted on May 08, 2007
  • 1294 Answers
SOURCE: washing machine stops mid-cycle and full of water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
esbee0522
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
Yozzer6821
  • 116 Answers
SOURCE: Door lock light flashing
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
Posted on Nov 09, 2008
Front loader leaking out the front door as is clothing stuck in it, How can we release the door lock. We've stopped the cycle.
Restart the machine...
On a NEW CYCLE... The first thing the machine
should attempt to do... is to drain itself.
If it does not...
UNPLUG IT... Restart it on a spin cycle ... or regular
wash cycle...
Carnac the Magnificent YZQ7YL
Jan 21, 2017 | Washing Machines
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
My Electrolux Front Loader stops mid cycle and then resets back to the start! It cannot finish a load?? There are no error messages being didplayed!
This may be a circuit board problem whenever it tries to reverse spin or drain some of the water...
what type and how long a cycle ....or does this happen with all cycle options?
Apr 15, 2014 | Washing Machines
MY MACHINE STOPPED MID PROGRAM. the red light indicating the door is locked is not on so i suspect this is why it stopped. the door itself is locked and will not open. the machine is full of clothes and...
You haven't given the machine make and model. The door lock is electrically operated and so if the door will not open even after unplugging the machine from the mains power, then the door lock has probably shorted and got stuck (welded contacts due to excessive power). This may also be the reason why the machine stopped and the red light is off. The mains fuse may also have blown. This used to be a common problem on Hotpoint washing machines. A track on the program circuit board would also burn out due to the current. The repair in this case was to replace the door lock and repair the burnt out track.
In terms of emptying the machine, if this is a front loader, then try banging the front of the machine where the door latch is situated. This may be enough to free the lock mechanism. If not, then remove the top cover AFTER FIRST DISCONNECTING THE POWER, and see if you can get access to the door lock form inside. It should be possible to dismantle the control panel and free the front of the machine, which will still be attached to the rubber drum seal.
May 25, 2011 | Washing Machines
My 7.5kg Electrolux Washing Machine whent bang and
your door lock has blown/short circuit turn power of disconnect plug take top of machine look down inside machine toward door lock and you shoud see the catch push hard with your finger and door will open be careful as there are some sharp edges in there.
May 31, 2010 | Electrolux Washing Machines
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Washing Machines Logo
251 people viewed this question
Top Washing Machines Experts
