I have a problem with my Panasonic SA-AK18 Stereo's cd player. I displays "No Disc" when there is a disc in there! I tried the disc in all 5 trays and they didn't work! Please Help!
SOURCE: My panasonic SA-AK750 hi fi
Tienes que llevarlo a un centro de reparaciones ya que el sistema de cd esta fuera de tiempo por eso no funciona nada.Hasta que no lo pongan a tiempo no va a funcionar.
Posted on Apr 06, 2008
VOTIT
  • 2071 Answers
SOURCE: I have a panasonic 5
It is the chrome rails bars grease that's hardened already causing to jump the disc. Due to accumulated dust and dirt to the grease.Just take out the old grease with an alcohol and change it with a type-A grease,only put a little amount...
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
hope this may help;
DON'T FORGET TO RATE;
Regards,
VOTIT
Posted on Jul 28, 2008
thaurfen
  • 623 Answers
SOURCE: I have a Panasonic SA-AK300
panasonic manual http://service.us.panasonic.com/OPERMANPDF/SCAK500.PDF
Posted on Aug 04, 2008
  • 4234 Answers
SOURCE: 5CD changer SA-Ak640 will not open
The loading mechanism has jammed somehow. When powered on, the unit attempts to get to a known position. If that fails, the message you indicate is displayed. The only way to resolve this is to dis-assemble the unit and rebuild the mechainsm. This should NOT be attempted without the service manual. There is a particular way to re-assemble these so that the gearing is correct. There are small gears and levers that need to be aligned properly. Also, there may be a broken lever or gear that needs to be replaced. I have rbuilt a number of these and the parts (if needed) are cheap (<$4 total).
I wold suggest that you bring this to an authorized Panasonic service center.
Dan
Posted on Oct 16, 2008
SOURCE: We have the RCA RS2767i
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Fred
Posted on Mar 06, 2009
Why won't a cd disc that I "burned" play on my Panasonic CD Stereo System?
Try cleaning the lazer lens in the Panasonic cd player. Dust can cause it not to read the disk.
Nov 11, 2014 | Audio Players & Recorders
Need to copy manual for home sterio system sa ak18
Hello
Get into this website, from where you can download the user manual of your stereo system in Adobe Acrobat document. If you feel any difficulty in downloading the manual, send your email address to me by FixYa. I've the manual and I'll send a copy of it to you by return mail. OK
www.usersmanualguide.com/panasonic/cd_stereo.../sa-ak18
Jun 02, 2011 | Panasonic Home Theater System System
When I put a cd disc in it is reading "no disc"
your laser has gone bad. replace it. Look up in youtube for how to do this.
Apr 09, 2011 | Panasonic SC-AK18 CD Shelf System
I have a Panasonic SA-PT250 surround dvd player. It plays most formats, but often displays "Error" and "Can not play Disc" although the same disc plays on a friend's dvd player. My...
some branchs are locked for some regions, and dvd movies are open forr all regions.
try to unlock your dvd and the problem will be solved.
look in the internet how to unlock your panasonic dvd, its easy.
Feb 14, 2011 | Panasonic Televison & Video
Error f61
my CD Stereo System SA-AK18 turns off itself displaying f61 error, what does it means? how can I fix it, plz help me
Oct 16, 2010 | Panasonic SC-AK18 CD Shelf System
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Nov 26, 2007 | Panasonic Audio Players & Recorders
146 people viewed this question
 Grubhead
Grubhead
