Question about HP Asus Motherboard P4SD-LA Socket 478 DQ182-69002 5187-6671
Video froze during operatiom. after re-boot, no video, no bios screen, nothing. Swapped video cards, cleared CMOS, checked power supply and CPU, HELP !
  • John Kasse Apr 04, 2011
    PSU good, tried alternate, tested one that was installed, no change
    This version of the PDS4 doesn't have on board VGA. Will try RAM check,
    Thanks , will let you know
  • 81 Answers
If you hear a beep, then that means that it cleared through POST. If you hear one beep, it's fine. More than that, you will need to know how many.
If it's twice, it's the Video card. I suggest to take it out, and use a VGA cord and connect it to the VGA slot on the built-in graphics on the motherboard. That SHOULD work. If not, there might not be a problem with the video card at all. It might be a RAM issue.
To know that, you will need to take out one RAM stick at a time and try starting it up. If you have multiple (2+) you will continue to add the sticks until the computer doesn't boot again, and you will find out which of them is bad.
The power supply would not be an issue, because if your computer froze during a video operation it would have nothing to do with the other causes.
Please Rate. Thanks.
Posted on Apr 04, 2011
  • 1 more comment
  • Eddie
    Eddie Apr 04, 2011
    Like I said. Try testing with the VGA built into your computer. If it still doesn't work take out all of the RAM sticks and try to see if one of them works by putting them in one at a time, and trying to turn on your computer after each one is in.
    OK, re-checked power-up, no beeps. Swapped around RAM, no change. Should I re-flash BIOS ? Made a floppy from HP site....
  • Eddie
    Eddie Apr 08, 2011
    Does it show the BIOS screen at least? Or doesn't even do that?
  • HP Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Hp thinclient t5730 power light comes on but will not boot. No video.
Thin, means no HDD.
means network is down.
or BIOS set up all wrong.
the ethernet card is set up to boot form the host server.
so both the lan card must support this and the BIOS setup to boot to lan.
what does no video mean , BIOS DEAD>
no video me means no text ever no matter what,
hit the BIOS keys , and when reset , you see that the lan boot is off by default on most PC,
RTM manual yet setups
https://support.hp.com/us-en/product/hp-compaq-t5730-thin-client/3634720/drivers
Aug 30, 2017 | HP Computers & Internet
E4406a needs 5min to boot and frozes up after key-touch (any-key)
Try to reset the CMOS
Disconnect all devices and power supply from board. Remove the CMOS battery. Remove the memory and CPU. Let sit for a few minutes.
Re-install all removed and check BIOS setting.
Load BIOS setting to default.
Check if your memory is correct Clock and not mixed.
Check CPU and board temps
Last of all, check your USB ports on the board and make sure that you have no bent pins or shorts.
Hope this helps
Apr 11, 2014 | Computers & Internet
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Won't start - tested power supply - it is good - removed cards and drives still nothing. Board looks okay - no holes - canisters are flat - what next?
re-seat the memory - how did you check the power supply - its fan working does not mean it functions properly - if you have spare try that one.
Sep 01, 2009 | E-Machines T3085 PC Desktop
PC wont start/boot
hello...i think you need to check all socket connection on the board and you need to check the memory or try to reset the Bios.or check the ATX power supply it is good or working..thank you
May 08, 2009 | eMachines D3415 PC Desktop
Not booting Properly.
have try to reset bios if not u have to reset bios.
Pullcmos cell for 15 seconds from mohter bord also u can reset bios with jumper settigns it is near cmos read carefully on motherbord u can find jumper u can see "clear cmos " on motherbord
May 06, 2009 | Fujitsu Siemens LifeBook E8020 Notebook
Singlle long beep on booting up my Biostar M7NCDPro motherboard with nothing on screen
If you get one continuous beep (Long and Non-Stop)
This could happen if:
1. The Power supply is damaged or bad.
2. The BIOS is corrupted. Try resetting the CMOS using JCMOS1 jumper on the motherboard or remove the battery from the motherboard for 20 minutes. At this point the first thing to try is a different Power Supply to see if the result is better. If the same problem happens with the new power supply, you may need to send the BIOS Chip to local dealer for reprogramming.
If you get one long High Pitched tone that does not stop until you disconnect the power supply:
1. Check if the CPU fan is connected to the JCFAN1 connector.
2. The CPU might be overheated. Change the CPU FAN or check if the CPU fan has proper contact with the CPU. Refer to your manual for CPU installation.
3. Clear CMOS battery (JCMOS1), be sure to set JCMOS1 back to 1-2 position. (See Quick start guide/ user manual for more info on how to clear the CMOS)
4. Make sure the power supply you have on your system supports the M/B specification. Example. If you have a P4 M/B, you need to use an ATX v2.03 specification power supply. (power supply that has an extra 4-pin square connector)
Sep 15, 2008 | Computers & Internet
7F debug code with no video output
do you see a bios screen at all or you just dont receive a signal at all?
Feb 13, 2008 | Jetway 939GT4-SLI-G Motherboard
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
HP Asus Motherboard P4SD-LA Socket 478 DQ182-69002 5187-6671 Logo
102 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
