Question about Fujitsu Plasmavision PDS-4221 42 in. Television
Fujitsu P50XHA10US Fujitsu plasma has a grid like pattern of black lines going through the screen in a very uniform manor (looks like a peice of graph paper almost). The lines don't show up over the menu box when its pulled up but they do show over top of any image on the screen even when im watching my cable box which is hooked into the component video jacks. I've tried the other set of component video jacks and i get the same problem.
SOURCE: Black screen after 5 minutes of use with Fujitsu PDS-420 plasma
most of the time, when the power light stay green, thr filter capacitors in the power supply have lost value, & need replacing.
When the power light turns red it indicates loss of signal. This could be the same problem except the input signal has been lost. Try replacing power supp;y caps , about 4 of them.
Works 90% of the time. Hobby of mine, Art
Posted on Dec 29, 2007
ripleymojica
  • 643 Answers
SOURCE: vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Posted on Jun 03, 2009
  • 534 Answers
SOURCE: Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Posted on Jun 05, 2009
tomlanik
  • 17 Answers
SOURCE: Confused on tv hook to Dish Network Box up Fujitsu Model#pds6101w
Call Dish Network for connection support
Posted on Sep 10, 2009
  • 1039 Answers
SOURCE: fujitsu plasma tv is on but no picture
Check all inputs. Are they all dead. Try other signal source. Does antenna input work when connected to known good source?Vide input label being displayed indicates most of the tv is working. You need to determine if you have lost signal in the video input.
Posted on Nov 09, 2009
Testimonial: "Thanks so much! I feel like an idiot...not technical at all, and hubby is out of the country. You solved the problem, though!!"
P50XHA10US plasma monitor dead no power..
Check and replace the main power regulator board as card basis. There is practicaly no repair to plasma display power supply boards.
Sep 21, 2013 | Fujitsu P50XHA10 50 in. Plasma Television
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Sep 05, 2012 | Office Equipment & Supplies
My vizio vp50 hdtv10a changes differant colors when it turns on, can i fix it myself? what is the problem
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergnce select that and wait a minute the TV will adjust itself and give you a clear picture. If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the curser (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture. You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
Take care in solving the problem...
Aug 22, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
The screen is distorted ... double words and double picture
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synchronous.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
Good luck in solving the problem....
May 27, 2011 | LG 50PG20 50 in. Plasma HDTV
P55XHA40US 55 in. Plasma Television: My Fujitsu Plasma screen has a blue tinge in the m...
You have a faulty PDP unit. These parts are no longer availible and even so the repair is not economical due to the price.
Regards
May 16, 2010 | Fujitsu P55XHA40US 55 in. Plasma...
I accidentally pressed the 2nd button and then the left side arrow button and now I have this black grid on my screen that I cant figure out how to get rid of if I tilt the screen I can see what I'm trying...
Displaying the grid on the screen is a graphing option accessed through the command GridOn. To turn the grid off, press [2nd][ZOOM] (FORMAT). Use down arrow to reach the 3rd line. Highlight GridOff and press [ENTER]. Press Graph to return to the graph screen.
How you activated the GridOn command by a single press of a button is a prowess. I wish you could teach me this legerdemain.
Hope it helps.
Nov 05, 2009 | Texas Instruments TI-83 Plus Calculator
SC 329 code Aficio 550
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
3. Press the “Enter” key.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
dpi).
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
16 Not used
21 Blank Page
Dec 12, 2008 | Xerox WorkCentre 490CX All-In-One InkJet...
Fujitsu Plasmavision PDS-4221 42 in. Television Logo
156 people viewed this question
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
