Question about Lexmark P915 InkJet Photo Printer
Lexmark p195 to change the printer off photo mode
I need program to instale printer
Posted on Aug 14, 2008
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
Had the cartridge filled instead of buying a new one. I was told at costco that the printer sometimes shows low ink when it's filled to check the manual there is an option that needs to be changed. I...
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed
Another thing which is mentioned at their support site is quote:
If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
If you find my answer helpful, please vote. Thank you!
Nov 16, 2010 | Lexmark X8350 All-In-One InkJet Printer
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
Changed the ink to a brand new one, now the printing is dull. i have realigned it and cleaned it nothing seemed to help
Check whether the leaver near the catridge is in Envelop printing mode. Change it to normal will resolve your problem.
Thank you for using Fixya.
Jun 27, 2010 | Lexmark P350 InkJet Photo Printer
"remove all of the memory cards and press select"
I'm glad the printer's working now. Great job! If you need more assistance, leave a comment and I'll get back to it. Thanks!
May 07, 2010 | Lexmark X6570 InkJet Printer
Lost instructions. What cartridges does printer
Here is the manual for your printer with instructions:
http://www.lexmark.com/publications/eng/7100/index.html
Here is the full spec info on your printer.
Print Resolution:
4800x1200 dpi best mode - Photo paper
2400x1200 dpi best mode - All other media
Print Speed:
mono draft mode 22 ppm
color draft mode 15 ppm
Copy Speed:
color draft mode 14 ppm
Fax Speed:
33.6 Kbps
Cartridge Compatibility:
  • Black: Moderate Yield – 32
  • Black: Standard Yield – 34
  • Color: Moderate Yield – 33
  • Color: Standard Yield – 35
  • Photo: Standard Yield – 31
Connectivity:
USB only
Media Handling:
Paper: Up to 150 sheets (20 lb or 75 g/m2 bond)
  • Envelopes: 15 envelopes
  • Labels: 35 sheets
  • Transparencies: 75 transparencies
  • Hagaki: 45 cards
  • Card stock: 35 sheets
Size & Weight:
490.8mm x 422.7mm x 305.4mm (W x D x H)
9.34kg
Scan Resolution:
  • Optical: 1200ppi
  • Interpolated: 19,200 x 19,200
Jan 08, 2010 | Lexmark X7170 All-In-One InkJet Printer
Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Change default ptr setting for lexmark x8350
4. Press "Select."
7. Press "Select."
Photo mode problem
Usually if you completely uninstall the drivers and software that came with the printer, then reboot your computer and reinstall the drivers and software - it will make a problem such as you describe go away completely. If it doesn't, then a technician will need to physically inspect your machine for problems. You also want to be sure that you have the most current version of the drivers and/or software for your machine. The Lexmark Driver download page for your model is here: --> http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0 Hope that helps. ;)
Aug 04, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P915 InkJet Photo Printer Logo
219 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
