Question about Canon PIXMA MP810 All-In-One InkJet Printer
Just replaced the black ink PGBK on my Cannon MP810 printer and kept getting error msg "wrong printer head". Took printer head to World Cartridge and they cleaned but still get the same msg. "wrong printer head". The same problem happened x1.6 years ago and end up paying $210 for service and replacement print head. Anything I can do without paying that much averjbitsky@hotmail.com
    Guru:
  • 352 Answers
Dont go to Cartridge World :(. This problem is sometimes caused when a cartridge has been re-filled and re-set too many times, The chip corrupts and causes some very weird messages. Simply try a New Set of Cartridges (Not reconditioned or Refilled). GnL Products in NSW have new compatible cartridges for about $10 each. gnlproducts@live.com.au
Posted on Apr 04, 2011
Canon mp810 black ink leaking
I dont know whats wrong with the screen but since its spilling out on the pages the ink container might be linking so just replace the ink but before you do clean the inside of the printer as well.
Jan 13, 2013 | Canon PIXMA Office Equipment & Supplies
Hi - I have a 3-4 year old Canon Pixma IP4500. The initial problem was blurring in places on black text. Nozzle check showed that bottom half of PGBK grid was missing horizontal lines. Took out the print...
one idea is that you rouined printhead with tap water and second idea is to buy new print head or printer.
Note: If you want to replace ink head, be sure to replace purge unit and ink absorber also.
Sep 02, 2011 | Office Equipment & Supplies
Hi We have a Cannon MP600 printer. Just replaced the large black cartridge (PGBK 5) as it had run out. The printer is now smearing gaps in the text (in black). Tried 2 cartridges & both produced the...
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged and showing the line gap in printing. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
Jan 08, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Installed Office Depot ink cartridges, BCI 6 C and Y in my MP780. Worked ok at first, but then started getting "wrong cartridge" msg, Per canon rep, turned off mach, disconnected power, took out...
This is an example of why 2nd class refills are junk. I would try to gently clean the printer out. While a lot of people disagree with this advice, a mixture of 90% alcohol in a tiny pipit works well. Then use some lint free q-tips. Most cartridges have electronic chips on them that report the status of the cartridge. Refilled ink cartridges may have bad or defect chips.
Jan 04, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I am getting a "wrong print head" error message.
Turn the printer off.
Disconnect the power-cord from the wall-outlet.
Reconnect the power.
Turn the printer on.
If you still get the same message, it's time to responsibly recycle the printer,
and buy a replacement -- maybe you can buy a new PIXMA that takes the same ink-cartridges???
Dec 08, 2010 | Canon PIXMA MP810 All-In-One InkJet...
How do I remove the print head from my Canon MP810 printer for a clean? :o)
I just replaced my MP810 printer head. Procedure: open printer - remove ink cartridges - Pick up arm located on right side of cartridge holder- remove printer head by picking up by the cartridge slots. Place new printer head in holder - replace printer cartridges - press arm down and your done....However, the error message stays on and reset procedure doesn't remove it. Canon tech support said their solution (because of distance from canon support) is to replace MP810 with comparable printer, which came to $299 with 15% discount and free shipping. My solution, I’m checking out other printers.
Jan 11, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Canon ip4300; new printhead and PGBK ink cart but it won't print
call ok canon 800 number..their better than India CAll centres.
Dec 03, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
May 30, 2009 | Canon MP610 Photo All-In-One Printer
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
255 people viewed this question
old marine
old marine
