My computer keeps trying to boot from another source
  • Maria Bronx Apr 04, 2011
    Thank you for your reply but there isn't an advanced settings option when I press f2 it goes set up which is only information, main, security, boot and exit with different options for each but nothing says advanced settings under boot it shows the boot priority order and it's codes that I don't really understand
BOOT SEQUENCE
1 diskette drive
2 internal HDD
3 usb storage device
4 cd/dvd/cd-rw drive
cardbus NIC
onboard NIC
Posted on Jul 16, 2011
  • 81 Answers
You would have to go into your BIOS by hitting the F2 key as it is turning on. Then go in, and under Advance settings, make sure that the only place that it boots from is the Hard Drive. Make that the primary.
If it still has an error coming up, then it might be a file system issue with the OS.
Posted on Apr 04, 2011
Computer won't boot and can't figure out why. Keeps going through the loop that's shown in video.
Try unplugging the computer from the power source while its doing this. Wait 5 minutes, then plug back in.
With any luck it will reboot. Its worth a try.
Nov 02, 2012 | Computers & Internet
How can I fix my laptop
  • You are right, your computer cannot find a harddisk to boot from as your device option to boot is from the dvd drive or from lan (network). Your harddisk might have failed, the cable has come loose or infected with a virus.
    BIOS is basic input output system, the program a PC's microprocessor uses to get the computer system started after you turn it on. When bios is shadowed, It means this program is copied from ROM to RAM during bootup for faster access. Source(s): http://wickedwebdesign.com.au
Feb 11, 2012 | Computers & Internet
Computer wont start
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB.
If same problem persist, boot from safe mode. Here's how;
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected, not Repair Your Computer
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would
If same problem persist, try reloading the Vista again.
Hope this works.
Mar 15, 2011 | Microsoft Windows Vista Home Premium...
Why the projector is keep searching
Hi
Is the projector directly connected to the computer? The setting on the projector might be set to auto detect source, could be one reason why when you boot your computer up its detecting for a source where it is attach to. You can set that to manual and by the way change the cable since it seems that the device is unable to detect any source.
Hope this helps
Apr 01, 2010 | InFocus In2106 Projector
T30 laptop - no picture on screen
It sounds like you may have the computer set to boot to an external monitor source. Try using the fn key and whatever "f" key up top that toggles the monitor source. if this doesn't work, try pressing f8 when booting up and boot into windows safe mode to see if it may be a driver issue or some kind of resolution issue.
Good Luck!
Jesse
Jan 04, 2010 | IBM ThinkPad T30 2366 Notebook
Had a power outage and now computer keeps rebooting. saw solution about going to my computer properties advance and unchecking automatically reboot, but cant' get there because computer keeps rebootin
hi
while rebooting u press the F5 key for a while, it will redirect u to a boot menu,in this boot menu u have some special options to boot like boot in safe mode,safe mode with networking ,debugging mode,last known good configuration boot,start normally,etc u first boot in safe mode and try to deactivate rebooting in ur own technicand u have more options try all of them it will be ok in 2 or 3 options
Thank You '
Dnt Foget to Rate me
Apr 21, 2009 | Acer Veriton M410-UF9500P Desktop
Toshiba satellite A205 will not boot
Re-installing your operating system should fix your boot-up problem.
Check your cmos battery to see if it is inserted correctly and that it still holds a charge.
Aug 01, 2008 | Toshiba Satellite A135-S2276 Notebook
My computer won't boot! It keeps restarting before Windows screen.
Make sure the cmos jumper is plugged in. Turn off your pc, unplug the power source. Remove the cmos battery for 30 seconds then put it back. Reboot your pc. Give us feedback! Hope that helps :-)
Jul 25, 2008 | Abit IC7-G Motherboard
Black Screen
try hooking up an external video source. Check to see if the computer is actually booting up. if the computer boots up, then the LCD invertor or Backlight of the screen is bad, need to be replaced.
If the computer does not boot up after hooking up an external video source, then most likely your motherboard is bad!
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 29, 2008 | Computers & Internet
Open Questions:
Which type of business should startups incorporate? Each unregistered or registered business works below a form and the business is working under what kind of form makes a huge effect on the profits of the business and business as well. Selecting a business form is similar to selecting a car, where various models are available. But you need to pick one which is best for you. Here we are discussing some type of business which a startup wants to incorporate. Partnership Partnership is a type of organization of business where two or more partners operate and handled the business. All the partners are personally and equally liable for the business debts. It is very simple to form a partnership. There is no need of minimum capital in the partnership. To incorporate a partnership, only two partners are required. Up to some extent, partnership is similar to the proprietorship. The main difference is that partnership requires a minimum of two partners. Two or more partners can begin a business. A partnership can also be registered. A partnership can be easily transformed as a private company. LLP Limited Liability Partnership A limited liability partnership or LLP is a distinct legal entity and it can be incorporated easily. A minimum of two persons are required to form an LLP. Its main aim is to make profit. It can be easily formed in a country like India. The benefits of traditional partnership and private limited company are enjoyed by an LLP. Due to enhanced regulations and rules in the private limited company, it is better for a startup to form an LLP, if in the future, they do not want to increase investments. Sole Proprietorship A sole proprietorship is a simple form of business below which a person can manage a business. A sole proprietorship is not described as a legal entity. It is known as a person who is liable personally for all the debts and business is owned by him or her. In the India, after the beginning of the One-Person Company concept, it is not beneficial to form sole proprietorship. Private Limited company A private limited company is a highly popular business form. A minimum of two persons are required to form a private company. It is an ultimate business form. The reason is the private limited company owners can perform any kind of transactions of the business as per their liking. One Person Company OPC is considered as a modified form of sole proprietorship. To form an OPC, only one person is needed. Benefits available to a limited liability company or LLP are enjoyed by the OPC. Public Limited Company In the India, a public limited company is a type of highly powerful business form and it is a very big company. If you are a startup and want to expand your business, then incorporating a public limited company is an ideal option for you. This type of company is registered under the companies act 1980. A minimum of seven members are required to form a public limited company. Also, there is no limit on the maximum number of members.
Jul 16, 2018 | Option Computers & Internet
Computers & Internet Logo
David Payne
David Payne
