Question about Compaq Presario CQ60-220US PC Laptop
I have a computer and it was working fine until i pushed the monitor fn toggle thing, Now i cannot get the external monitor to turn back on
  • 81 Answers
You will have to play around with the FN + (monitor toggle) key a few times. There are about 2-4 settings made, so you will just have to press it, give it a few seconds, and then try again until it comes back.
Then I would restart the computer just to make sure it works.
Posted on Apr 04, 2011
How to turn on
What?............Oh, okay.............I was going to watch this Disney movie though..........
JUST KIDDING!
http://www.asus.com/ph/Notebooks_Ultrabooks/ASUS_VivoBook_X202E/
1) Laptop OFF, monitor OFF, attach a VGA monitor to the VGA port, on the laptop.
(Right side, all the way to the back)
Or you can use the HDMI port, and use an HDTV.
The HDMI port is on the Left side.
Turn the monitor/TV on.
Turn the laptop on.
Does a display show on the external monitor/TV?
No?
Hold the Fn key down, and tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
Go to what you are using as an external monitor. VGA monitor, or HDTV. Hold the Fn key down, and tap the F8 key until you get what you want.
Have a display on the external Monitor/TV?
Problem is NOT the graphics chipset.
Problem is the Video Cable, or LCD/Touch screen.
Post back in a Comment, as to the results of the external monitor test.
Regards,
joecoolvette
F8 key is display toggle over
Apr 25, 2013 | ASUS VivoBook X202E-CT033H Touch Laptop, 1...
Hp laptop no longer connects to external display via fn + f4
The Fn+F4 button toggles between the LCD and external monitor.
From LCD only or both LCD and external monitor or external monitor.
only. Press the Fn+F4 keys again to toggle the various screen selections.
Sep 16, 2012 | Computers & Internet
External monitor only works if I start windows vista in safe mode
First after you boot it up normally (not Safe Mode) can you move the mouse far to the left or to the right do you see the mouse. If you do see the mouse pointer you are running dual monitor mode and the laptop screen is set as the primary monitor. You have to run it in Save Mode and set the external monitor as the primary monitor. Hit the Start button then select Help+Support and in the search box enter "dual monitors". Read how to set up the primary monitor.
Second maybe you need to activate the external monitor. When laptops boot normally (not Safe Mode again) with a external monitor connected you have to hit the Fn (function) key (probably blue near Alt key) and some other number key (it probably has a blue monitor symbol on it) I'm not sure which one. This key sequence is a toggle sequence. In other words when you boot a laptop it goes directly to the laptop screen then the first time you do a Fn + number key combination it will turn on the external monitor and turn off the laptop screen the next time you push Fn+number key it will turn on both monitors (external and laptop screen) the third time it will turn on only the laptop screen and so forth.
Aug 19, 2012 | HP Pavilion dv7-1245dx Notebook
Power is on but no signal output to the screen
The following applies to Acer Laptops. You did not specify the brand of laptop you had. If your laptop is not Acer, the specific keys mentioned may be different and you should adjust accordingly.
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
Apr 04, 2011 | Computers & Internet
Model acer travelmate 4000 nodisplay on lcd and external monitor
You say the trouble is with the keyboard. Can you attach an external keyboard via USB and see if you can push Fn key with F5 (I think it is the F5 key - try Fn with others - keep Fn pressed and repeatedly press the F5 or F6 etc.) several times to see if the screen toggles between LCD and external monitor. For this to work you will have to restart the computer after attaching the external keyboard. Press the start button until the computer goes off, and press again to restart.
Itf you ascertain that the trouble is with the 99.N7082.01D, make sure to try to fit it in correctly, or perhaps the Fn key has some dust or liquid in it so it does not function. Then you have to try to clean it from the inside after you disassemble.
Jan 07, 2011 | Acer TravelMate 2300 Notebook
I have a everex stepnote XT5000T and the it turns on but the screen stays black.what could be the problem?
It may be that the display output toggle has been set to "external monitor" ... try Fn+F3 .... to toggle it from your screen, to external monitor to both ... and see if the screen works.
If this doesn't work, connect an external monitor to your computer, and toggle it, to see if the monitor displays the screen contents. If this works, then it's possible that your LCD screen is faulty ("fried")
Aug 11, 2010 | Everex StepNote XT5000T Notebook
I am using an acer aspire one netbook on xp. i can not make the external monitor that i attach to the serial port to work. is just shows, "no signal" When i press fn f5, it still won't work. please help.
Hi, Could you please post the Model Number of the computer.Are you trying to connect using a VGA cable or a HDMI ?Fn+F5 key combinations are used to toggle the display between the laptop and the External Monitor.Try these steps
1.Remove all cables,Turn OFF computer and Monitor
2.Start the computer and wait till it boots to windows nrmally.
3.Start the Monitor,then plug the cables between laptop and Monitor.
4.Check with Fn+F5 to toggle display
Jun 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
No display everything turns on windows loads but no display
We can further isolate the issue by connecting an external monitor to the notebook. If the display is fine with the external monitor, this clearly indicates that the issue is related to the LCD screen. Otherwise, it is due to the some other internal hardware.
You may follow these steps to connect the notebook to an external monitor.
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
External monitor.
May 14, 2010 | HP Pavilion DV9620US Notebook
I have a new dell laptop. I have connected an external monitor to the laptop because the screen is bigger. The monitor has been working fine with my other computer that died. This monitor I have also used...
To activate the external VGA port on the portable Press the Fn key + the F8 key. This is a 3 setting toggle
1. LCD only
2. LCD & External
3. External only
You just press Fn+F8 again to cycle thru to the next setting
Jul 08, 2008 | Computers & Internet
Compaq Presario CQ60-220US PC Laptop Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
