Question about Abit AB9 Pro Motherboard
Abit ab9 pro , bios doesn't recognize DVD roms
  • Abit Master
  • 27,725 Answers
Make sure that the dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Posted on Apr 04, 2011
When i try to suspend my pc, my motherboard gets f3 error and then restarts. The model is an old abit ab9 pro. I recently changed the ram and my os. The os runs perfectly.
have to select suspend mode s1 or s3 in BIOS power management to check the support mode, also check with hibernate, also need to free space in hard drive system partition for hibernating
Sep 11, 2016 | Abit AB9 Pro Motherboard
I re installed windows XP and now my ethernet
You can find drivers for your motherboard at the following location:
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AB9+Pro&pSOCKET_TYPE=LGA775
Scroll down and look for: Realtek Gigabit Lan Driver
Aug 02, 2010 | Abit AB9 Pro Motherboard
Hi , my abit pro 9 bios doesnt safe ,,want to install windows on a new empty drive but therefor i need to change boot device , i choose cd rom , then F10 to safe , but it freezes there , doesnt safe ,,,...
for your first boot cd/dvd rom, 2nd boot hdd is it serial ide or sata, then you can disable the 3rd boot device, if it freezes and does not save reboot your pc in some motherboard there is key to press for you choose which device to boot first if you find the key sometimes its f12 or f10 when press this it will promt which device to boot first then choose which of those devices you want to boot first
Oct 22, 2009 | Abit AB9 Pro Motherboard
When i power on a led is blinking next to the mb power suply and apears two errors 82 and 98 i have tried diferrent power suply, ram, vga card
remove the bios battery for 20- 25 mins.small flat round battery on the motherboard then put it back in. start up computer
Aug 05, 2009 | Abit AB9 Pro Motherboard
Manual and Bios for Abit AB9 Pro Motherboard
Hello seany187,
What I'm doing since your system doesn't want to download from Abit, is creating a zip file with all the drives, manuals, utilities and bios updates for both XP, XP64, Vista, and Vista 64, since I don't what OS your on, and you will be able to download them from this private site HERE. And because the files are so large, I split them into, I'll post the second one as in a comment as soon as it's completely up on the site.. You shouldn't have any problems with these downloads, unless you have your IE settings to high.
Good Luck & don't forget to leave a rating based on my Solution.
Thanks Mark
Stay tuned for the second file!
Apr 06, 2009 | Abit AB9 Pro Motherboard
ABIT AB9 PRO WILL NOT POWER UP
Sounds like it's going to die or its gone faulty,
Might need to replace it or take it to a computer store and have them check it out.
Dec 28, 2008 | Abit AB9 Pro Motherboard
CMOS setting distrubed for mercury PVM7 ver 1 board
just press del to enter to the cmos and then change the date and time of cmos and press F10 to save your configeration if you start the cpu again and if you see the message "press F1 to continue and del to enter bios it time to replace your cmos battery inside of cpu is like a coin inside of your computer
Nov 24, 2008 | Abit AB9 Pro Motherboard
ABit AB9 Pro 775 PCI Express Problems
I have the same board - no problems - the video card I'm using is eVga Nvidia 8600GT.
Nov 02, 2008 | Abit AB9 Pro Motherboard
C1 code, computer won't boot
get the battery out of the socket and reset CMOS by jumper after you unplung the pc's mai power supply
Oct 24, 2008 | Abit AB9 Pro Motherboard
Badly flashed bios
i can fix that if only you are in my country(Philippines)
Sep 22, 2007 | Abit AB9 Pro Motherboard
Abit AB9 Pro Motherboard Logo
151 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
