Question about VinoTemp (VT60GNV) Wine Cooler
I plug my 50 bottle cabnet in and nothing happens, I had a power surg at m y house and I beleave that's when it started. Can't say for sure because I don't check on it all the time
  • 132 Answers
It is quite possible an internal fuse on the cooler has open circuite.
Try plugging in a desk lamp into the wall socket. If that works then you will need to get a technician to check your cooler for you
Posted on Apr 04, 2011
Heater is not working on my 2005 chevy impala
put a radiator flush in the expansion bottle.run it for about 20 miles.that will clear any rust or dirt..then drain and refill with a 50/50 mix of anti freeze.bleed the air out .do that by heating on full .with the expansion bottle cap off .replace when you start to feel water getting hot.
Dec 10, 2013 | Cars & Trucks
Lg 50pq3000-za plasma tv will not switch on from main button on the bottom of the tv and from standby it clicks and the red light comes and goes and nothing happens its only a few weeks old..
power problem possible fried power capacitors
possible cause power surge could occur if unplug while tv on
must change 6 power capacitors
these original capacitors are on the low end minimal ratings
1-2 hours in house labor, cost est $200 plus minus
Jun 06, 2010 | LG 50PQ30 50 in. Plasma HDTV
Computer won't turn on won't do anything , i had it connected and someone at my house was using electric drills and the fuse tripped and everything was shut down including my computer and since then it...
Try unplugging the computer completely from the wall for 15 minutes. Plug it back in, and see if it will power on.
If it doesn't it's most likely a blown power supply, when the breaker tripped, everything on the circuit basically fed back into everything plugged in. This is something most computer power supplies do NOT like.
The good news is, a power supply is generally pretty cheap, you can get new power supplies atarting around 20 bucks, although decent quality ones are closer to 50 bucks. Bad news is, there is about a 1 in 20 chance the power supply took other parts with it.
Once you do get it running, or get another computer, make sure to get a surge protector strip and plug everything connected to the computer into the surge protector. A 15 dollar surge protector can save you 150 dollars in parts and labor. (or more)
Sep 27, 2009 | Computers & Internet
VAIO Will Not Power Up
It is possible that the power box is dead.
Or try this open your box and disconnect the power supply from the mother board and put in beck. And try and boot up.
Aug 10, 2009 | Computers & Internet
What kind fo antifreez to use
use an aluminum approved only coolant.
nothing else.
mix up a 50 -50 mix and poor it in the radiator over flow bottle.
some gallons are ready mixed allready just make sure.
any auto parts house will have it for you.
hope this helps
thank you
jm
Jul 16, 2009 | 2003 Chrysler PT Cruiser
The temperature icon does not light up so you can read the numbers. I can't set it on the correct temperature. It keeps gong back to 70.
when you are setting the temp the display shows the set value .. but when you release the buttons for a few seconds the display reverts back to the actual temp inside .. so if you set it at 55 deg F .. after a second or so it will jump back to 70 or whatever it happens to be at that time inside the cabnet .. eventually it should go down to your set point (several hours) .. but mine didnt .. it stayed at the room temp forever .. the fan was running but the solid state cooling device actually had no power (requires about 4 amps at 12 volts).... the problem was a blown fuse in the power supply inside the cabnet .. make sure the unit is not plugged in if you are going to take the back off the machine ... in my case all that was needed was to replace the primary side fuse (about 2 or 3 amps i think) there wasnt but there could have been other problems as well .. the power supply is what they call an "off line switcher" when it is plugged in it has dangerous voltage and current levels .. so again dont plug it in unless it is assembled in a safe manor ..
the same power supply might power the "back light" for your display ..
Jul 13, 2009 | Oster 12-Bottle Wine Cellar - Black
Tower won't turn on
Brandi,
Please check the following:
1. Make sure the the surge protector is securely plugged into the wall. Test this by plugging in a light / lamp to it, to make sure it's working.
2. Make sure that the surge protector is turned on.
3. Check to make sure that the power cable from the computer to the power surge protector is securely plugged in.
4. Check to see if the computer will power on now.
5. If this still isn't working, remove the power strip/surge protector and connect the computer directly to the wall.
6. If this STILL isn't working, try plugging your computer into a different outlet in the house to see if the outlet in your home might be bad.
6. If your computer STILL isn't powering on then I'm afraid the worse has happened, which is one of the following issues:
1. Bad power supply (they are cheap, around $20-40)
2. Bad motherboard (they are sort of pricey, around $50-200)
3. Bad CMOS battery (they are cheap, around $5-10)
I can fix all of the above and order parts for all of the above, if you are in need of parts.
I hope this troubleshooting guide helps you! If this resolves your issues, please mark this question as resolved and select my answer. This will assure customers that I can help them with their issues.
Thank you,
Larry Braziel
May 12, 2009 | HP Computers & Internet
My TV won't turn on
Unplug it plug it back make sure it does't have a main switch on it at the bottom. If your a novice call a lg service center.
Apr 25, 2009 | LG 50PC3D 50 in. Plasma Television
Last night I turned-off my PC througg Windows and when I pushed the power button this morning nothing hapened. There is no sign of "life" from the PC.
Check the power source to the computer (both ends of the cord), if a surge protector is in line with the power , remove it and plug the computer straight into the wall. also check the wall plug with a lamp or something to ensure power there. make sure the switch on the power supply hasnt been changed to the 220v side.
If no power at the wall- check your breaker box in the house
If it works plugged straight into the wall- check the surge protector
If power at the wall and plugged straight into the computer (no surge protector) and nothing lights up when you turn it on- have your power supply checked.
Oct 08, 2008 | Acer Computers & Internet
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
VinoTemp (VT60GNV) Wine Cooler Logo
214 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Mari Severino
Mari Severino
Level 1 Expert
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
