Can i hook additional speakers to this machine to place around the room if so how and what all do i need to do so
    Sergeant:
  • 378 Answers
More information is needed. What make and model of a receiver do you have. Most receivers do have the capability of connecting additional speakers.. Front Left, Front Right, Rear Left, Rear Right, Center, Sub-Woofer. Etc.
The back of the unit should have connections for such speakers. Just make sure you turn off and unplug the unit while making the connections.
Mark
Posted on Apr 04, 2011
Not outputting to all speakers from CD, but does from DVD
Hi,.
With the indulgence of the others...
If I understand your problem right:
1. CD works only in Speaker A (but not in Speaker B);
2. DVD works on either or both A/B;
3. CD will work if plug into to VCR input but selector must be of another source (not VCR).
A couple of suggestions:
a. pls try doing again the reset as ginko has suggested but make it a bit longer, i.e. unplug it from the mains for a couple of hours;
b. since you have remove most of the wiring, why dont you try switch A & B. make the family room speakers the B while the speaker selector the A;
c. hook the CD (only) using the RCA cables (red/white) nothing else;
d. play any CD music and go through the paces of selecting source, speakers, surround/hall/theater/etc as troylove11 has suggested.
This would be now a simple setup, 1 source (CD) to 1 output/speaker (the family room) via the Denon. Try different settings. If the CD plays normally then, without changing any setting nor powering it off (but with volume level all the way down), remove the family room speaker wiring and replace it with the wires to/from the speaker selector.
the idea is to determine which is the real issue, the Sony, the Denon settings/hardware or the speaker selector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 15, 2008 | Denon AVR-3801 Receiver
How to install a home theater
Follow these steps:
•Plan out your setup. Before you start unpacking speakers and moving furniture, it's a good idea to have a placement scheme in mind.
•2
Consider the location of the outlets in your home theatre room. If possible, choose a room powered by a single circuit breaker to reduce the risk of damage due to the overload your home theatre system might cause. Supplement the number of outlets with power strips.
•3
Place your TV. The television should be placed where it can be viewed straight on. The center of the screen should be aligned with the eyes of a seated person.
•4
Place your speakers before you start hooking things up. If there are hearing-imparied people in your household, place the speakers so that someone could sit directly next to at least one speaker.
•5
Position your central channel speaker above or below your TV. If you put it on top of your TV, make sure the front edge of the speaker is aligned evenly with the front of your TV screen.
•6
Place your front left and right speakers at equal distances on either side of your TV. The height of your left and right speakers should match the height of your central channel speaker.
•7
Put your surround speakers at equal distances to the left and right of where you would normally sit and view your TV. Do not point your surround speakers directly at your viewing position. Try pointing them toward the back of the room or toward the ceiling.
•8
Place your subwoofer to the side of the room, about halfway between your viewing position and your TV. You can adjust the bass reaction of your subwoofer by moving it closer to a wall to increase the bass, or by moving it away from a wall to decrease it.
•9
Connect your speakers and theater system by running flat speaker cables down the length of your baseboard or lower portion of your wall. Consult your owner's manual for exact instructions.
Mar 13, 2011 | Philips 55PFL7505DF7 55 in LCD TV
Can't get face plate off of MTX 610CM ceiling speakers
Its a pain, espicially if the grills were painted before installation.
In the industry we use a "grill puller" which is nothing more then a wire hook with a loop for your finger.
If the holes are big enough bend a paperclip into a hook, grab it with needle nose pliars and pull the grill through the hole near the edge.
If it doesn't fit then use a small pointed knife or awl, stick the point in a grill hole around the egde and pull it down a bit, work your way around until you can grab the grill with your fingers.
Let me know if you need anymore guidance......be careful I've replaced alot of destroyed speakers!
Cheers,
Kevin
Feb 03, 2010 | MTX 610CM Speaker
Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
Jul 05, 2009 | Yamaha RX-V463 Receiver
Logitech Z-5500 DON'T POWER ON. HELP!!!
check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
May 31, 2009 | Logitech Z-5500 Computer Speakers
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
Trying to hook up Zone B stereo speakers in two additional rooms.
The infrared mentioned by the manual is most likely an extension possibility to use the remote control in each room, forget that part.
What you need to do is quite simpel, after connecting all speakers, you should indicate in the setup menu of each zone which speakers are connected and do as follows:
in main room select 5.1 setup, for the other zone select only the left and right front speakers.
Your EXTRA SP indicates the extra speakers for 7.1 setup and when set to zone B it recognises only 1 speaker.
So read carefully the manual how to connect Zone 2 speakers and connect that way, than carefully walk through the setup menu to setup the zone 2 correctly.
Apr 09, 2009 | Yamaha RX-V663 Receiver
 Grubhead
Grubhead
