Question about DaVinci Emily Crib
Need to lower mattress to lowest posistion, how?
  • 22 Answers
1). remove the mattress, bedding and any load on the mattress spring.
2). remove the bolts attaching the support frame to the crib
3). reattach at the desired level.
4). reattach all 4 points and tighten. Do not overtighten.
5). Replace mattress bedding and any load.
Any further questions? Contact the manufacturer directly. They respondquickly and have the most accurate information for the SAFETY OF YOUR CHILD.
Here is the website for Million Dollar Baby, DaVinci and Babyletto:
https://milliondollarbaby.zendesk.com/home
Posted on May 22, 2012
3 Suggested Answers
  • 11 Answers
SOURCE: Lowering the Mattress
Call LaJobi (the manufacturer) and ask.
LaJobi 877-440-2224
Posted on Mar 30, 2009
SOURCE: Lowering the mattress
I have the same issue... can anyone let us know if you have managed to put the mattress on the lowest (4th hole) setting? PLEASE.
Posted on Aug 03, 2010
Jul 28, 2010 | DaVinci Emily Crib
I need to lower the base to its lowest setting but not sure how ?
Remove the mattress. in all for corners you should see metal arms that are attached to the mattress support. these arms will be screwed into brackets on the crib. Unscrew all four screws and re-screw them into the lowest hole available. replace mattress and your done.
Jul 10, 2010 | Baby Gear
How do I lower the mattress on my Bonavita crib quickly?
Most cribs have tabs on the rails of them .... take everything out .. bedding,mattress,etc. Take a look at the platform that the mattress lays in especially the corners.... You might see a hook at each corner that fits into a release tab unlock the realease tab and remove the hook. Do this for each side and reinsert the hooks at the correct level in the crib... If this is not the case you may need to look at the owners manual... But I think you should be able to get a good idea about how it lowers when you remove all the bedding out of the crib..... good luck
Oct 19, 2009 | Bonavita Peyton Crib
LaJobi 877-440-2224
Jan 19, 2009 | Graco Lauren Crib
Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
Sep 23, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Kinderkraft crib
You just take the drop down side off and put the mattress at the lowest setting. We have the same crib and used it for a few months as a toddler bed.
Jan 11, 2008 | Kinderkraft Vermont Crib
CONVERTING TO TODDLER BED
i found this on the simplicity website, hope it helps. i got mine done i minutes!!!!
Remove Drop side.
Lower drop side. Push in on the tabs at the
bottom of both lower tracks to slide the drop
side down off the tracks as shown.
Position Mattress Support.
Mattress support must be in the lowest
position. If not, use the allen wrench to
remove bolts. Lower support into position
and re-attach to headboard.
Remove upper and lower tracks.
Aug 29, 2007 | Simplicity for Children Ellis 4 in 1 Sleep...
Childesigns carrollton crib
I am not familiar with this crib, but I have been through many cribs and they all (so far) are adjustable to lower the mattress. You can figure it out by removing the mattress and matress board and inspecting the way the board is connected to the frame. Often there is a bar or rung that sits in a clip or groove at each corner of the crib just below the matress board. You may have to crawl underneath and look up at it. Usually you will be able to lower the platform without using tools, but be sure to take the weight off the platform by removing the mattress and board. Good luck.
Nov 14, 2006 | Childesigns Carrollton Crib
DaVinci Emily Crib Logo
122 people viewed this question
Top DaVinci Baby Gear Experts
Dennis Fitzsimmons
Level 1 Expert
Are you a DaVinci Baby Gear Expert? Answer questions, earn points and help others
