Question about DeLonghi EAM3400 Espresso Machine
Hi, My Delonghi Magnifica 3500 infuser is stuck halfway out. I forgot to turn off the machine before removing it, and now it's stuck. Any ideas how to fix it? Thanks.
ginko
  • 19396 Answers
SOURCE: tried to remove infuser, must
Here is the complete user manual with pictures on how to remove the infuser.
If you have more queries ask us.
If you are satisfied with solution, do not forget to rate best solution.
Many thanks
Posted on Aug 20, 2008
SOURCE: Magnifica gives Generic Alarm Message - Infuser stuck
My infuser was stuck in the down position, When I called customer support the told me some easy steps to fix this problem..try calling them
Posted on Mar 12, 2009
  • 3 Answers
SOURCE: DeLonghi Magnifica always asks "Insert Infuser Assembly"
on my machine, the two screws that attach the infuser receptacle to the insides of the machine came loose. You can see those two stainless hex socket screws when you remove the infuser by grabbing its two red tabs and pulling it out. Just use a hex shaft
screwdriver (size 3mm or thereabout) to tighten them.
Posted on Apr 18, 2009
SOURCE: infuser stuck up my delongi magnifica
I have a problem. I removed the infuser and the internal bracket is now in a "down" position and I cannot get the infuser back in. I need to know how to raise the internal bracket to its proper place. Any ideas?
Posted on Apr 10, 2010
SOURCE: delonghi magnifica coffee machine...infuser jammed
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Posted on May 03, 2010
Delonghi magnifica has exclamation
Switch the machine off, AND pull the plug, wait 5 minutes (to be sure) and turn it on. Then turn it off again, now the infuser should return to it's normal position where you can take it out.
If the descale button is still flashing, try descaling again. Was the procedure interupted before? That would be a reason the light keeps flashing.
Bert
Nov 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
Unable to remove infuser, no warning light, reset multiple times, brews coffee fine
You should go to test mode and try moving infuser up and down to position when you can take it out it needs some skill of timing. After that you need to disassemble infuser completely clean it up and lube with special food grade lube. Also there could be a problem with transmission kit that cause this problem.
Mar 22, 2014 | DeLonghi ESAM3300 Magnifica...
Defuser unit stuck at bottom of Delonghi magnifica coffee machine. Squeezing red buttons does not help. Cannot remove
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
Aug 21, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Infuser is stuck at bottom of machine
hi, try turning the power on at the machine like you would normally do , then turn the power off at the machine again, not at the power point this should make the infusser pull back.
cheers
Jan 03, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
'less coffee' error message
The infuser assembly can only be removed with the machine turned off. The infuser needs to be removed and cleaned at least monthly; more often if you use your DeLonghi at lot.
Jun 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Infuser stuck up my delongi magnifica
Apr 06, 2010 | DeLonghi Coffee Makers & Espresso Machines
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
Nov 28, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
DELONGHI 3500
delonghi 3500 turns, runs diagnostics and then shuts off. Won't turn on unless you pull the switch. Any Ideas?
Jun 03, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Open Questions:
See all DeLonghi EAM3400 Espresso Machine Questions
DeLonghi EAM3400 Espresso Machine Logo
94 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
