Question about Nextar GPS
Where is the reset hole - Nextar GPS
  • 17,970 Answers
First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted.
Hope helps.
Posted on Apr 04, 2011
How do i factory reset my kuno tablet that i forgot all passwords to
Look for a small pin hole in case, usually says reset next to it. Use a paper clip in the hole to press reset button. Power on while momentarily holding down reset button with clip. Then power on again, should be back to factory settings. If there's no pin hole the you hold down on off the f keys while powering up. Try googling tablet name & model factory reset.
Jun 09, 2015 | Tablets & eReaders
Pls l have try the reset don,t work what wil l do now
Toothpicks are tapered, and might not go far enough in the hole to fully depress the reset button.
Try the end of a paperclip instead, that is the tool the hole and switch were intended for.
If you try jamming the toothpick in further, you run great risk of having it bust off in the hole and really messing things up.
Jan 23, 2015 | Computers & Internet
How do i hard reset my tablet?
look for a reset hole arround the device.just press it for more than 10 seconds and it is all(always the reset hole is near the pluggings holes like charging,earphone,USB connection)it is a very small hole that you have to use a pen or an unfolded clip
Jun 19, 2014 | Craig CMP741d Tablet
My screen is frozen
Depends on make, model, but look for a very small hole in the back, this hole is a reset button. Use a paper clip straightened out and press the tip in the hole to reset your player. If your does not have a small hole, then go on line and find out how to do a reset for your make and model.
Sep 02, 2011 | Audio Players & Recorders
How to renew my passport?
check on the router there would be a reset hole or reset botton, you can press that reset botton or inset some pointed device into the reset hole and reset the hole
Aug 09, 2011 | Computers & Internet
I forgot my username and password
Depending on the router... but, usually get a pen or paperclip... find the reset hole which is usually in the back of the router...
  1. unplug the router
  2. put in the reset hole the pen tip or paperclip (better) and maintain pressure on the button inside the reset hole...
  3. plug in your power cord.
Your router should flash for a moment and then you get release pressure from the reset hole and the router will load the defaults of the router from when you purchased it.
Apr 20, 2011 | Computers & Internet
Can i reset my tomtom one v3 to original factory settings
yes you can rest your tom tom. If you don't know how to do the reset, follow the steps below:
  1. Remove the TomTom GO from its cradle.
  2. Turn the unit upside down.
  3. Look for a small hole in the bottom of the unit. It will be located just behind the release button. The reset button is recessed inside this hole.
  4. Straighten out one end of the paperclip.
  5. Press the recessed button by inserting the straightened end of the paperclip into the reset hole.
  6. Hold the button down for ten seconds, then pull the paperclip out of the hole. Your Tom Tom GO should now be reset back to the original factory settings.
Take care.
May 28, 2010 | Tomtom ONE 3rd Edition GPS
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
My Zen V Plus mp3 froze on me how do i reset it
1. Find the reset hole on the side of the player, just below the power/hold switch. DO NOT MISTAKE IT FOR THE MICROPHONE HOLE AT THE TOP.
2. Push a paper clip in the hole, and the player should automatically shut off.
3. If your player does not shut off, you must wait for the battery to die, but mostly, the reset hole works.
Sep 24, 2008 | Audio Players & Recorders
My screen is screwed
PLEASE RESET USING THE RESET PIN PRESENT IN THE SIDE!!
AND FORMAT THE PLAYER ... GUESS PLAYER HAS INFECTED BY VIRUS!!
Mar 03, 2008 | SanDisk Sansa e200 MP3 Player
GPS Logo
105 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
