Menu keep on poping up when tried to exit it goes back on the screen over and over.
  • Computers & ... Master
  • 27,725 Answers
Try uninstalling a few unnecessary programs
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
another one of the possibile reaons is
a bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to finish its cycle and have an end so any faulty leads will end up with a computer error
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
Posted on Apr 04, 2011
The monitor's menu keeps poping up
if you manually press the button that accesses the 'menu' at other times, does it work ? (as in maybe the menu button is stuck down ?)
Aug 28, 2012 | E-Machines eMachines Desktop PC
My LG T.V's Menu keeps popping up and wont go away, when i try to exit off it, it just pops back up, sometimes it doesnt go away the after a few minutes it does then comes back, I dont have any extra...
The tv manual control buttons board like POWER,MENU,INPUTS,CHANNELS - +,VOLUME - + could be bad and causing this problems.Take the tv aparts,unplug the connection that plug of the mamual pc board functions,the tv will work as normal only no manual buttons functions,if the Menu screen stop poping up,than u know the manual control buttons board is bad must be replace.If Menu it still poping up,than u have a bigger problems,the tv Tuner signal board is the cause and the problems.That the board,that take in the incomming broadcasting cable wire is the problems.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes boards like the manual control buttons board or the tv Tuner signal board.
Mar 23, 2011 | LG W2284F 22" 2ms LCD Monitor - Black LCD...
The TV keeps going to the MENU on it's own...When you exit to TV it goes back to menu within 5 seconds
Hey djames1971 - did you ever get this resolved? My Philips is doing the same exact thing now; sooooo annoying. If I keep monkeying with the exit setting it eventually goes to the TV and stays there, but it doesn't fix it by any means. Next time I go to turn it on I have the same battle with it.
Jun 15, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Magnavox 32'' LCD, Menu being displayed on the screen all the tim
Magnavox = Philips,for some sets there are software update's available.U can update te TV via USB.
Dec 08, 2009 | Televison & Video
Main control screen keeps popping up on my windows xp computer while im on other sites..please help!!!!!!!!
Is this your monitor menu screen that keep on poping up. the monitor or the screen is not set properly. unlpug the monitor wait 10 seconds and replug back in. if you have video driver install it. 95% this will solve your problem. If you have samsung lcd flat screen press auto button.
Jul 27, 2009 | Dell Optiplex GX270
Screen menu auto-adjust ghost
never try to fix crt monitor you need a new one cos thay are so cheep cost you lots for reppers ,bye an lcd ,,,,nice
Apr 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
Monitor Menu Poping up again & again
1. First U can change Microswitches on front pannle (Menu,select,+,-)
2.check dry points in MICOM&EEPROM IC,HV IC and It's related.
3.check 5V supply and replace 5V Regulator.
Oct 05, 2008 | IBM E74 17" CRT Monitor
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
CM2015 15" LCD Monitor
Sounds like the buttons are sticky. Open unit and clean with electronic cleaner. May try spray with unit off.
Mar 30, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
