Question about Kwikset 4 Lido Lh Passage Levers Satin Chrome 200ll 26d
I'm replacing my front door entrance with a kwikset Shelburne Tustin lever 800SEXTNL 15 SMT CP. the hole is in place from the old hardware. I can't find the instructions. How do I secure the bottom part of the handle to the outside of the door. It looks like a need to drill a hole and run a screw into it from the inside, but how do a line that hole up with the hardware?
  • 963 Answers
Her is the link to the installation guide for your lockset, which you can cut and paste into your Browser. It is a PDF file, which requires that your have a PDF reader like Adobe Reader installed on your computer:
http://s7d5.scene7.com/is/content/BDHHI/28741-05
Posted on Apr 10, 2011
How to tighten kwikset #991LL
Remove inside lever by loosening the setscrew and pulling. Carefully pry off the inside cover. Make sure both screws are tight. Replace inside lever. With door unlocked, the outside lever can be removed in the same way as the inside. All that is necessary though is to be sure the setscrew on the outer lever is tight. Check to be sure the lock is tight and operating correctly before closing the door and locking it.
The deadbolt inside turnbutton is held on with a small setscrew. Remove it and the inside cover. Be sure the screws under the cover are tight. Check the lock operation, replace cover and turnbutton.
Jul 07, 2014 | Kwikset 991ll 15 Smt Cp Lido Entry Lever...
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
When I enter the code the lock opens but the unit flashes ten times...is this ok?
To find your answer you can visit and download a manual @ http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HieMAAS.aspx. . :) Best of luck!
Sep 12, 2012 | Kwikset 909cnt 15 SMT CP SmartCode Single...
I Have a new Kwikset 909 LO3 SMT CP unit - How do I change door handedness?
In section 8 of your instructions is the "Door handing" programming instructions
Link here: http://s7d5.scene7.com/is/content/BDHHI/Website%20Content/Kwikset/Resources/KwiksetSmartCodeManual.pdf
You need to carefully go through this programming routine without interruption. That should fix it for you. Good luck!
Jul 05, 2012 | Kwikset 907 L03 Smt Cp Powerbolt
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
WHERE CAN I FIND A MANUAL FOR MY KWIKSET SIGNATURE SERIES WITH SMARTKEY KEYLESS DEADBOLT LOCK 909 15 SMT CP? I need to change the combination and have misplaced the original manual.
I think this is what your looking for... click link below.
http://www.kwikset.com/smartseries/smartcode.aspx
click on the correct link to your system at the bottom of the page when you get there.
Best,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Jan 02, 2010 | Kwikset Professional Door Lock...
Need to disassemble deadbolt with concealed screws
If it's like my deadbolt, pull the inside faceplate off. It's just pressed in place and the screws are behind it.
May 30, 2009 | Kwikset Powerbolt/Electronic Deadbolt-...
Kwikset 4  Lido Lh Passage Levers Satin Chrome 200ll 26d Logo
152 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
