Question about Frigidaire GLTF1670A Front Load Washer
Shakes wildly and loudly in spin cycles
This is the second Frigidaire front loader we have owned in the last 6.5 yrs and the second to experience the same problem! At first I thought it was just an out of balance load, but it has continued since.
  • 876 Answers
These machines do not do well if they are installed on certain types of flooring. They jump around when they spin and generally go nuts! I have one, so I've seen them do this. Ours was sitting on pergo which is very shiny and smooth. The washer did this most of the time. My husband bought a small commercial rug that has rubber backing which really sticks to the floor and put it completely under the washer. I changed the way I load the clothing. For example:
Don't overload
Don't mix very heavy items like towels with very light items:
Heavy together andnot too many
Light together
A repairman told us about the floor and I read the rest in my manual. Our washer works fine now.
I hope something here will help you as well.
Posted on Aug 06, 2008
  • 3,037 Answers
The bearing has gone bad and will need to be replaced. It is located towards the back of the machine and so the back panel will have to be removed to access it.
Posted on Aug 05, 2008
SOURCE:
My Frigidaire washer shakes horrible and vibrates the whole house. It is level on the floor what could be the issue?
You don't specify if you own a top load washer or a front load. I'm sure that the noise is present when the machine goes into spin cycle. One thing that you might try is to put the machine on neophene pads. You can find these at most hardware stores and if your machine is on a wooden floor, it can really help, especially if it's a top loader. Neophene is a great sound insulator.
Dec 22, 2009 | Frigidaire Washing Machines
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Loud noises during spin
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | LG WM-1832C Front Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire front loader washer makes a very loud knocking sound during the spin cycle before the final rinse. It intensifies the longer I allow it to spin. I have to shut it off before the cycle is...
from your description, it sounds like your washer is already broken - to check, open the door and reach your hand into the tub at the front top. push up. if the tub moves more than a fraction of an inch, the bearing and/or spider are toast. last time i checked, the PARTS were in the neighborhood of $450 and it's a BIG job! [read that: big labor bill]. this is a common problem with these machines and it's probably time to get a new washer. sorry!
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag front loader shakes really loud
make sure the transport tie downs have been removed during installation and that all four feet are adjusted properly so machine does not rock.Also make sure your floor is reasonably solid.
Sep 25, 2008 | Maytag MAH21PD Front Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front Loader- drum is loose
Dear Katie
ngfam at you service,
Sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 25, 2008 | Frigidaire ATF6000ES Front Load Washer
you basically have to replace the whole bearing assembly. Well, the first thing to do, is remove the outer panel on the machine and then the drum should come off and you should be able to get to more parts quite easily.
Aug 19, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Frigidaire GLTF1670A Front Load Washer Logo
97 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
