Try using the soap tablets instead. The frigidaire units use a small cylinder to actuate
the soap dispenser and if just a little too much soap is used the latch will bind and not
release. Alternatively, make sure the dispenser is only about half to 2/3 full if you need to
use powder detergent. This is a common problem with the frigidaire/ whirlpool/galax/kenmore
models. Hope this is useful.
Hi
Dishwashers use Bi-Metal strip to
allow the dispenser to open/close. This strip when heat up causes the soap door
spring to open up the dispenser. If this strip is not heated doesn't allow the
door to open. The strip may not be getting 120V or maybe disconnected. Newer
(plastic liner) dishwashers use a wax motor to open the soap dispenser. The
plunger inside the wax motor slowly moves and pushes the plunger and door
open. And, if this wax motor doesn't receive 120 volts, then it'll not work.
Please check the voltage to the wax motor/Bi-metal strip; also inspect the
connections to these.
Hope this helps...
Daniel
Hi
Hope this helps...
Daniel
