Question about Westinghouse LTV-19w6 Television
Westinghouse LTV-19W6 TV Won't change channels
I purchased an Westinghouse LTV-19W6 TV about 5 months ago. Now all the sudden it won't change channels. It stays on the same channel and neither the remote or the buttons on the side will change the channel. What is wrong and can it be fixed? Thanks!
  • 3 more comments
  • petermoss44 Sep 03, 2008
    I have the exact same problem, I dont know exact model number but mine is a 19 inch plasma/lcd
  • pjaykelly Dec 01, 2008
    I have the same problem with that same television. I can only change the channel if I type in the station I want. I cannot change the station on the tv or remote by going up or down. If you find out what is causing this and how much it cost to fix it, please let me know.
    I called Westinghouse and their customer support is non existant. 2 of the the numbers I called are individuals - not Westinghouse. I thought Westinghouse was a good brand name. Maybe I was wrong.
  • Anonymous May 06, 2009
    Same Problem except sometime the volume controls won't work either. It must be a problem with that particular TV model. I've tried some universal remotes..and they also have the same problem. The tv just won't change channels! I've spent 70+ dollars to get it looked at...and they still didn't fix the problem.
  • Unsatified Consumer Sep 12, 2013
    Mine will not change channels either. And, of course, not response from Westinghouse
  • Anonymous Mar 31, 2014
    westinghouse tv changes channels on its own
  • 3 Answers
An email from Westinghouse that fixed the problem for me.
Thank you for your inquiry.
We apologize for any inconvenience in waiting for our response, but below is what I can suggest to move forward.
It appears all you need to do is run a channel scan on the unit. Once you have run a channel scan, you will be able to scroll through the channels using the channel up and down buttons.
If you have any further questions, you may contact us through email, or by calling us toll-free at 1-866-287-5555, between 9am and 9pm Eastern Standard Time, Monday through Saturday. One of our technicians will
assist you.
Posted on Dec 04, 2008
I had the same the problem.  My tv would not change channels.  I had to run the tv through my dvd player to be able to view my cable channels.  The one solution listed did work for me.  Set your source to menu on your remote control...go down to the 4th the right arrow...move down to CH Auto Scan and press the right arrow.  The tv will scan for channels and once complete I was able to change channels again.
Posted on Jan 10, 2009
Model VR-4625 wont pick up any channels with auto scan
Look to see correctly hooked and that in the menu the set is now not set to catv or cable but to air/antenna. If no antenna connected to set or if just indoor antenna you may not pickup on auto search--try to direct enter a known channel with the remote--if you get one you can in the set menu manually add to the memory the set has.
Nov 06, 2012 | Westinghouse LTV-19w6 Television
I have a westinghouse tv model ltv -19w6, buy I don't have a remote control, I'am trying to set a universal control, buy I don't have de code for this model. can you give me the code please.
What's the make and model of the universal remote? A common brand is one4all,
If you find the model of the remote, you can find the book and the code for your TV.
Apr 25, 2011 | Westinghouse LTV-19w6 Television
What is the universal remote code for a Westinghouse LTV-19w6?
You can try code 0463, although its a long shot.
Alternativley....this may work (a manual code search):
Turn on the device that you want to control. (TV)
Then press that device key on your remote once and release (the TV key as an example).
Press device key a second time and hold for at least 3 seconds, and release.
Hopefully, the device key is now flashing. Next, start pressing channel up repeatedly until the device you are trying to control turns off. When this happens, press the device key, this will lock in the code.
Note: When the device shuts off, you may have hit channel up before your brain realizes what happened (i.e. you will be one code hit channel down and then the device key if you think you went to far)
Hope this helps!
Mar 28, 2011 | Westinghouse LTV-19w6 Television
I need the remote control code for Westinghouse ltv-19w6 tv.
If a generic brand remote doesn't list "Westinghouse," you're going to have to order a factory original. Went to Comcast site, scrolled down, and it said Westinghouse is........0463
Jul 04, 2010 | Westinghouse LTV-19w6 Television
Unable to turn off my westinghouse LTV-19w6 tv
your backlight inverter is permanetly on .that is the tft lamps do not off . the on & off voltage off your inverter is not working
Nov 11, 2008 | Westinghouse LTV-19w6 Television
Problem with my ltv-19w6 flat screen TV
hi your tv will  not show picture if there is no cable or antenal connected insted it will show u the blue back baground
Sep 29, 2008 | Westinghouse LTV-19w6 Television
Channel changing by itself.
I will tell you that westinghouse is the worst company among other brands. If you have warranty, return it and buy a sony or panasonic with a little extra money. It will help you later from buying another TV that is also as crappy as westinghouse's.
Oct 01, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-19w6 Television Logo
2,641 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
