Question about Ariston Technologies Washing Machines
I was washing towels on cotton (1) cold water , at the end of cycle during drying a F-02 keep flashing on the control panel. This is a new machine used about 3 months
    Genius:
  • 1,400 Answers
Hello
F02 Is a suds error code or water is to soapy.You need to use the E A type soap.
Try running the machine on rinse and spin.And then go through a normal cycle with no soap.
Posted on Apr 04, 2011
Malber WD1000 wont condense the water that is fed through during the drying cycle
Since it drains properly during the wash cycle, we know the drain pump and its impeller (propeller) work, and the coin trap (you called it a filter) and hoses are not clogged. By the way, turning the rightmost knob to "4" will start the pump-out cycle, so you don't have to open that trap-door at the bottom. To condense, the machine needs COLD water (spritzing on an internal screen) during drying. Make sure your cold water hose is connected to the outside (outboard) connection on the back of the machine. As a long shot: If the gray drain hose is pushed too far down into your home's drain pipe (more than 8") there could be a "back-siphon" where dirty water siphons back into the washer. It's a long shot, but it does happen.
Lastly, the controller board (mounted at top of right side) could be bad, and not sending on-off commands to the pump during drying. During drying, the drain pump should cycle on and off constantly, every few minutes. Do you hear it running? If you remove back (about 12 Torx screws), at your lower left you will see the pump. There are only 2 wires (120 VAC) and they can be connected either way. Stick a meter on the terminals and see if power is cycling on and off. If not, the controller board is bad.
You can order one from Malber (in NYC) by calling Nancy at 516-323-5299. Tell her Mike, in Wash. D.C., says hi.
Mar 06, 2015 | Malber WD1000 Front Load Washer/Dryer
Hotpoint WDL520P Washer dryer Filling up with water as it should during the drying phase untill the end of the cycle when it fills up entire drum with water constantly during this cycle it is constant
The other logical point is that it can be related to a faulty output or error from the program controller output. In some cases choosing an alternate program cycle can confirm this case of faulty cycle patterns.
Feb 12, 2013 | Washing Machines
New Cannon towels are soft but totally nonabsorbant.label says 100% cotton 100 %aragon
Wash in cold water, and use fabric softener as well as dryer sheets when drying at low heat on dryer. To hot of water and to hot o drying will cause this.
May 08, 2011 | Washing Machines
I just had the LG WM3987HW washer/dryer combo installed on Saturday, and it will not dry our clothes. This machine is ventless and dries by dehumidification. The clothes are more dry at the end of the spin...
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
Nov 29, 2010 | LG WM3987HW Front Load Washer / Dryer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
I have a whirlpool duet. I had washed 8 towels 2
To get inside the machine for a look, you have to take the back panel off,
1. Pull the plug
2. Turn off and then Disconnect the HOT and COLD water hoses at the machine
3. Remove bottom, side and all but 2 top corner screws from the back panel (all around the outer edges only) then supporting the panel, remove one corner screw, let the panel down on that side, then remove the other.
4.Remove panel
5. Grab a light, look inside.
My guess is that the spinning, wobbling drum worre a hose thru.
Good Luck!
Hint: Put all the back panel screws in loose, all the way around... then tighten them
Mar 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How to drain liquid chlorine?
Get as much as you can out with a towel, then flush the rest with cold water. Just pour it in and dry it out with a towel until you are able to pour water in it and it go out the dispenser like normal. After you have gotten the dispenser cleaed out you will need to get the detergent out of the machine before using it. Start a cycle with cold water. Let it start washing, when you see suds forming pour in a little vegetable cooking oil. This will kill the suds. Keep doing this through the cycle. After the suds are gone and the cycle is done, run it through another cycle with hot water. If you have no suds you are done. If It still suds up by the end of that cycle, run the cold wash and vegetable oil again.
You should be ok by running one cold and one hot, just watch it and add a little oil to kill the suds.
The cooking oil trick works with dishwashers too if you ever put the wrong detergent in them.
Please reply if you need any more help.
Oct 23, 2007 | Kenmore Oasis 27042 Top Load Washer
Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Oct 16, 2006 | Candy DQW150 Front Load Washer / Dryer
Washing Machines Logo
163 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
