Question about Honda Gxv160 55hp 55 Hp 1" To 78" Lawn Mower Engine
The pull rope for starting will not rewind, so therefore, I can't get mower started. I don't have a manual
    Novelist:
  • 111 Answers
Almost all of the Honda starters are the same. Hope this helps you.
Posted on Apr 04, 2011
Kholer engine engine repair
remove starter houseing cut old rope out then rewind it till it stops slip new rope through houseing hole and pull hole put a screw driver threw houseing and pulley to make it so it cannot unwind then not the pulley end of rope take a lighter heat knot this will make sure it will not unknot hold rope pull out screw driver pull rope until knott is seat to pully slowly let cord rewind cord until it stops pull out two tune of pully install handle put knot in it and heat the knot with a lighter done cut excess cord off reinstall the red neck let me no if you get have problem like motor dont star or is hard to start
Aug 28, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
Diagram of how to rewind rope on 1979 seaking model vwb 52179
Watch a video. Go to youtube, top of page type how to fix recoil rope on lawn mower.
May 21, 2012 | Garden
How do I reset the starter cord to rewind. It does not recoil when I pull it to start. I have to take the cover off and do it manually.
Hopefully you don't have a broken recoil spring. If the spring is not broken, then it's just a matter of rewinding the starter rope with the spring tension wound. I'll give you links to my two favorite videos on how to do this, as each machine is similar, yet slightly different. After viewing both videos, you should be able to do this on your machine:
Video1: http://www.youtube.com/watch?v=GyjQir3b3xI
Video2: http://www.youtube.com/watch?v=i3ZMVFi0yqY
I hope this helps. Best of luck to you.
James
Sep 06, 2011 | Mtd 22" Yard Machine Push Mower
Replaced starter rope on 5.5hp honda engine, can't seem to rewind it so it recoils when I pull start
Most of the rewind applications require you to pre load the recoil with a certain amount of turns before you wrap the rope on the pulley.
Nov 30, 2010 | Garden
The rope broke on my lawn mower and I am trying to rewind the spring, but was advised to buy a complete starter assembly, I need to know how much one is and where can I get one. I bought my lawn mower from...
If your rope broke, there was no reason to take the spring out. The rope can be replaced just by taking the rewind housing off, turning pulley to get rest of old rope out, wind the pulley (and spring) the direction the rope would be pull it when starting. Then , when it's wound tight, back off to align the holes in pulley and cover. Hold it there, stick about an 8' piece of rope from the outside through the pulley and tie a knot. Hold the rope and let the spring pull the rope back into the starter. an tie handle back. Take your housing, and spring to a shop. They can re-install the spring and put on a rope a heck of a lot cheaper that buying that whole assembly.
Jun 16, 2009 | Mtd 22" Yard Machine Push Mower
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
Replacing starter pull cord on Cub Cadet mower
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
May 05, 2009 | Garden
Rewind don't work
as you put the side with the recoil starter back on the saw, ensure the rewind pack isn't binding. before tightening the screws, pull the rope out a few inches and let it rewind. if it won't, something is binding. keep moving the side panel till it will rewind. I have done this before myself. get it all put back together and it won't work.....
Jan 29, 2009 | Poulan Pro Chain Saw 46cc 20"
Starter Rope Rewind Problem
I need to replace rope on my lawnmower starter, are there any tips on this?
Dec 11, 2008 | Toro Lawn Mower With Toro Power Tools
Honda Gxv160 55hp 55 Hp 1" To 78" Lawn Mower Engine Logo
531 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
