Question about Lowrance GPS
X 37 TX Lowrance as on 2005 Bass Tracker Boat Need part of mounting bracket which is broken.
3 Suggested Answers
  • 10 Answers
SOURCE: transducer is mounted on a
Are you utilizing another unit in your dash? If so, sometimes when both units are on and in sonar mode, their frequencies will intefere with each other causing the vertical lines. I would suggest turning your dash unit off or lowering it's Hertz rate from 200Hz down to 50Hz.
Funny story...I saw this same issue on my boat years ago. I had an X102C up fron and an LCX-19c in the dash. I acutally thought it was some sort of man-made structure and spent time fishing it...DOH!
Posted on Mar 25, 2009
TechnoMarine
  • 132 Answers
SOURCE: i have a e120 used to be in dash mounted. sold
we have them in stock good used 847-746-0100 www.technicalmarine.com
Posted on Jan 16, 2010
My new Lowrance Hook-5 GPS isn't working, I'm a noob, how do I get this function working?
'isn't working' is such a broad problem. If it is only the GPS, it is covered from Page 49 of the manual and shows you can access Satellite information. Note, it almost certainly won't work in your garage or storage. It need to see the sky as the antennae is internal.
The unit has an installation guide. In my personal opinion, it is better to let a professional boat engineer install it, mainly for the correct fitting of the transducer on the stern. Correct placing makes all the difference to a good set up, unless you intend to fish without the engine running.
All they need is mounting, power through a fuse direct to the battery, and the transducer fitting. Then you put the boat in the water and switch it on.
Installation Guide
http://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-5-SERIES_IG-MT_988-11024-001_w.pdf
Manual
https://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-SERIES_OM_EN_988-11004-002_w.pdf
Full Specs
HOOK 5 Fishfinder and Chartplotter
Apr 24, 2017 | Lowrance GPS
How do you start 1993 bass tracker?
Bass Tracker? Bass Boat? If its a tiller motor, yank the rope until it starts, or, your arms fall off, whichever comes first! If its electric start, check your batteries are good & fully charged. Make sure your "kill" switch is connected & you're in neutral. Turn the key. In fact make sure you're in neutral for the tiller motor also.
Apr 28, 2016 | Miscellaneous
Where do I place transducers on my boat?
That will depend on what transducers you are using. For different types of transducers you will get mounting brackets. These are usually available from the supplier of the marine transducer.
For example in-hull or tansom mounts.
http://www.lowrance.cn/en/Support/Tips-and-Tutorials/Transducer-Guide/
Sep 04, 2014 | Boating
Troubleshooting bass tracker boat
kill switch possibly problem.
Jun 26, 2013 | Boating
Transducer is throwing up a large Rooster tail.I installed it to instructions
Might help to tell us what kind of boat - deep V hull 22 ft.? bass boat with shallow V hull? Some need the transducer closer to the centerline of the vessel while others do better more outboard, Naturally they need to be flush with the hull no matter where they are located. Depending on the transducer, you could also try properly mounting it inside the vessel near the transom. Good new is you are getting good info from it. Cheers Pete
Nov 16, 2017 | Humminbird 586c
Need installation for pitot tube(Sspeed Transponder) and lms-332
manuals can be downloaded at http://www.lowrance.com/en/Downloads/Manuals/
You can probably get the parts from a dealer, or any marine electronics retail like Bass Pro and Cabelas or any of those kinds of places.
You can buy accessories from Lowrance at www.lei-extras.com
Not sure about the speed transponder? but if you are referring to the transducer, you probably need to go to this link
http://www.lei-extras.com/store/search.asp?SearchType=Category&Category=200+khz+transducer
That first item, part number 106-72, is most likely what you are referring to.
Jun 29, 2009 | Lowrance LMS-332C GPS Receiver
GPS Logo
80 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
