Question about Jenn-Air JDS9860A Dual Fuel (Electric and Gas) Kitchen Range
JDS9860AAP JennAir dual fuel convection oven fan does not operate. What is the cause?
5 Suggested Answers
  • 3422 Answers
SOURCE: have moved into a house
can you please give the make and model no. so that i can let you know if there is any user manual available for your model.
Posted on Jul 05, 2008
SOURCE: stove cleaning
The filter in the jenn air can be run through the dishwasher. clean the outside of the oven as best as you can before you start the self clean cycle. NEVER!!! use oven cleaner inside a self cleaning oven. or on the gasket. . You can use a degreaser or oven cleaner on the cooktop on any stainless steel, procelain or chrome surface. Don't get oven cleaner on painted or aluminum surfaces. Rinse off very well.
Posted on Jul 08, 2008
  • 476 Answers
SOURCE: My jennair burners ,fan and oven light work but
Replace the clock first(electric control) then test the oven it could be that it's why the oven does not work.
Posted on Jan 13, 2010
  • 53 Answers
SOURCE: Jenn-air dual fuel jds9860aap
Sounds as if you have a bad ground or nuetral wire connection. Unplug and check the connections to your control assembly and the pigtail on the range. I have also seen displays on Jenn-air go bad as well.Replace the clock assembly.
Posted on Apr 19, 2011
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
How do i make my convection fan turn off when i open the oven door
It sounds like there should be a switch on the door and it is malfunctioning. I would contact the manufacturer as it should be covered under warranty if it is malfunctioning. Especially for a $10,000 oven.
Dec 03, 2014 | Thermador Ovens
The fan doesn't work on the dual fuel convection oven. what should I do?
check power on fan motor 120 volt or not. if power 120 volt change fan motor
Oct 06, 2014 | GE Kitchen Ranges
I have the Legacy model 3530-3630 gas/electric stove.....my problem is this: for the past few days there is what sounds like a fan running in the oven. This runs constantly whether I am using the oven...
This is the convection fan. My hearland range does this too, after power loss in the house. I cancel it by starting and then stopping convection mode. ie. hit convection (fan icon) start (running man) and then cancel (X).
Dec 27, 2010 | Heartland 3530 Dual Fuel (Electric and...
The fan has stopped orking on my new world oven
I have no worked on a new world oven, but i will assume you speak of a convection oven.
Typically convection ovens have a door switch a motor and a run/start capacitor which helps the motor "turn over". I suggest, you have the oven cool, remove anything blocking the convection motor. Take your hand and spin the wheel, then while its spinning turn it on. You may have to try counter or clockwise. If you cant spin it at all, you have a bad motor, if the motor starts up with your manual assistance, the capacitor is bad. If there is not even a hum, a door switch is faulty, that or the motor has a thermal overload (usually a red button on the motor that needs resetting).
Dec 19, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Thermador RDSS30 Cooktop works fine. Oven will not turn on. Any button pushed says ''OFF''
My Thermador CT 127 Convection Oven will not turn on. Lights work, convection fan works, oven will not heat.
Jun 06, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Jan 03, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Jenn-Air JDS9860A Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
